Old 01-18-2007, 20:13   #1 (permalink)
Member: 414651
nokia 2600 hanging problem ? plz help.i flash with ufs but same. its urgent
Old 01-19-2007, 18:24   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
full flash the phone with good PM
post result
Old 05-31-2007, 12:33   #3 (permalink)
Member: 178616
Thanks Meter: 90
after pm
thanks it will done after pm but there is no service after writing pm and unlocking.any way thank for working solution..
Old 05-31-2007, 12:55   #4 (permalink)
gs cell's Avatar
Member: 308822
Thanks Meter: 380
change inner keypad or finelly its cpu problem
Old 05-31-2007, 13:30   #5 (permalink)
Member: 168789
Thanks Meter: 4
write thies pm it ggod
http://http://z33.zupload.com/downlo...filepath=32700
Old 05-31-2007, 13:33   #6 (permalink)
Member: 168789
Thanks Meter: 4
http://z33.zupload.com/download.php?...filepath=32700
The Following User Says Thank You to ahmed_fonc For This Useful Post:
Old 05-31-2007, 13:51   #7 (permalink)
Member: 244357
Thanks Meter: 70
reball flash ic . 80% of this type of problem when phone hanging
The Following User Says Thank You to bhardwajparesh For This Useful Post:
Old 05-31-2007, 17:11   #8 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
all these problem are not with softwares try to check that when the set hangs when you using phone beyond the capicity the set hangs, there is no way to work with nokia 2600 beyond the limit , the proccessing of your set became slow the data command from one ic to another ic transfer very slowly so try to make their route perfect,
by such as clean the board very nicely by dipping the board in the cleaner and reflow the total small smd's with antistatic soldering iron,
99% chances of ok
The Following User Says Thank You to yashtel For This Useful Post:
Old 05-06-2009, 22:03   #9 (permalink)
Member: 369369
Thanks Meter: 15
i have the same problem any solution please
The Following User Says Thank You to nicemanbilly For This Useful Post:
i need 2600 & 2600 uem LordMen007 Wanted Products 2 10-07-2005 22:07
2600 RH-59 flash problem trener Griffin 8 03-16-2005 09:18
Need firmware for 2600 (rh-59) chris_ua Nokia Digital Core Technology 4 ( DCT-4 ) 1 02-08-2005 16:54
Who can flash 2600 by use 1100 cable ? Vansy Griffin 1 01-19-2005 17:19
nokia 2600 don't call masci Nokia Digital Core Technology 4 ( DCT-4 ) 1 11-20-2004 20:28
Page generated in 0.19373 seconds with 9 queries
