2600 blue display 2600 blue display pls help |
change display. that display might be of 3120 . use display from a running set |
Check lcd connector Check lcd connector change it or see either on of them is damage or not.if damage then make jumper.but first be sure that with blue lcd do you receive call? if yes then check lcd connector if not then it is software problem.. kashif |
thanx alot............... |
try to dial 112 to make sure that the problem is only the display. if you hear a voice prompt when you dial the 112 it means the problem is the display |
mobile is running but 2600nokia blue display |
2600 blue dislay pls help me bro |
