Old 07-24-2006, 14:35   #1 (permalink)
Registered User
acelai00's Avatar
Member: 255011
Thanks Meter: 56
Red face 2600 cant power on.....
i have allready change uem and flash but same too......and i try flash the phone but appear
Old 07-25-2006, 04:34   #2 (permalink)
Registered User
acelai00's Avatar
Member: 255011
Thanks Meter: 56
help please........................!!!!!
Old 07-25-2006, 05:51   #3 (permalink)
s1emens's Avatar
Member: 40602
Thanks Meter: 118
As you can see fl0 information indicates that your flash ic is damaged and need to be reball or even change.
br,
s1emens
Old 07-25-2006, 05:57   #4 (permalink)
Registered User
acelai00's Avatar
Member: 255011
Thanks Meter: 56
bro i allready change and reball but same too.....
thanks your help
Old 07-26-2006, 00:00   #5 (permalink)
Member: 187930
are all flash ways not broken ??
change the flash ic with a new one
and change uem also , write rpl asic 2
if you changed the flash ic with no benefit..
sure it is a processor problem 100%
be careful upp is glued
change upp and try again..
try this steps and tell me
it will be good
good luck
Old 07-26-2006, 07:29   #6 (permalink)
Member: 275698
this is the flash ic problem
see f10 address, not shown the name of flash ic it means flash ic is damage,
2600 Not powering on by battery master_t2 Nokia Hardware & Hardware Repair 0 10-10-2007 08:03
3610 cant power on but wit power supply ok! uwenk98 Nokia Hardware & Hardware Repair 4 05-08-2004 06:01
S35, after changing PA cant power on pali Siemens Hardware Repair Area 4 11-20-2002 10:15
c35 cant power on pali Siemens Hardware Repair Area 0 09-20-2002 00:32
gd90 cant power on after.. timitiz Panasonic 3 11-11-2000 20:27
Page generated in 0.18256 seconds with 10 queries
