05-02-2007, 06:21 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: I.N.D.I.A(PUNJAB)
Member: 309398 Status: Offline Sonork: 100.1590052 Thanks Meter: 5,455 | 2600 dead 1st Boot Ok, DCT4, UPP: 1201 Fl0: 0x01000000-0x01FFFFFF,71A3361A, Algorithm: u_intel.fia, Ver: 4.57.0 Algorithm Ok, MSID: 84E646DA17A6BB19446179EA8C Decoded MSID: 3E4EBAE9-00011DB6-A8000000 Encoded FAID: D3A6577C-07F100C4-3A96F0C9 Erasing: 0x01000000-0x0100FFFF ... Erasing Error: 10, at: 0x01000000-0x0100FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile help |
05-02-2007, 09:05 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | brother clean baord with ctc, dry it, and after assembling phone check battery conecters (they should have a complete continuty not with dry solding) now attach phone with any supporting tool, make erase after that flash phone with almost latest version.....fbus cable should be in fine condition,,problem will be solve.... |
05-02-2007, 09:34 | #5 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: India
Member: 222373 Status: Offline Thanks Meter: 9 | dead 2600 Quote:
you need to reball flash ic becase Fl0: 0x01000000-0x01FFFFFF,71A3361A,(flash ic no. missing) this means flash ic is not connected on the pcb reballing will solve the issue else you need to change flash ic. this is the only solution to yr problem BR, Vilas | |
05-03-2007, 07:12 | #6 (permalink) |
Freak Poster Join Date: Sep 2006 Location: INDIA Age: 48
Member: 350948 Status: Offline Thanks Meter: 32 | Hi, you have check your cable while when u are flashing set perhaps it is not conecting to PCB or cause loose connection & try to flash. If problem also remains try to reball flash ic. |
2600 dead with twister? | damko | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 09-08-2006 19:50 |
2600 dead | unlocksolutions | Nokia Digital Core Technology 4 ( DCT-4 ) | 29 | 02-27-2006 11:58 |
2600 dead after failed flash | rob9099 | Twisterflasher | 11 | 08-08-2005 22:16 |
2300 & 2600 dead | aberiya | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 06-30-2005 13:46 |
2600 Dead | supremegsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 06-23-2005 07:37 |
