04-17-2005, 14:21 | #3 (permalink) | |
Cheater -Don't Deal with him- Join Date: Mar 2004 Location: GERMANY Age: 42
Member: 60523 Status: Offline Thanks Meter: 9 | Quote:
B.R ROBISH | |
10-05-2005, 07:18 | #5 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | remove the SIM driver IC and make jumper/short using some small wire. its easy to do |
The Following User Says Thank You to pazeth™ For This Useful Post: |
10-05-2005, 12:33 | #6 (permalink) |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | hi CHEAK BATTRY CONNECTER SOMETIME'S IT COUS INSERT SIM CARD.... WBR MUNNA +919810626677 e-mail- [email protected] www.gsmmunna.com |
The Following User Says Thank You to GsmMunna For This Useful Post: |
11-24-2005, 20:40 | #10 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | you must work on your sim chambers, sometime clean your sim card again before insection. this is a common trick. check your sim chamber very well, i will post you more developing. bestman |
12-09-2005, 13:32 | #13 (permalink) |
Freak Poster Join Date: Apr 2005 Location: BIRNAM MELROSE JOBURG S.A Age: 48
Member: 139349 Status: Offline Thanks Meter: 7 | 2600 dead hi mine has a different problem , it does not switch on after being droped so i cleaned and re-hoted the pcb and tried to flash with griffin v2.0826 but below is the massege i get ACTIVATED BOX using autopower Initializing Phone...Send 2nd loader failed, probable cause: *Too slow PC *Noise environment *Too long cable *Bad luck Error[5555B040]. so how can i solve the problem ???????? |
12-10-2005, 16:46 | #14 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 45
Member: 166746 Status: Offline Thanks Meter: 86 | yellowcom: check the batt pins, im sure they have a short soldier, re soldier them or put new onees, then u can check the board for any diodes that fell off when dropped, matcht eh board with another working boards and look for missing parts. wbr |
2600 insert sim | nkakanou | Nokia Hardware & Hardware Repair | 2 | 10-16-2007 19:26 |
2600 with insert sim problem | Arashdvm | Nokia Hardware & Hardware Repair | 5 | 03-13-2007 12:21 |
3100,1100,2600 nokia type insert sim card problems | uncle smallz | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 12-16-2006 16:03 |
2600 Insert Sim | LIONMOBILE | Nokia Hardware & Hardware Repair | 5 | 06-03-2006 14:03 |
3210 - "Insert SIM", but SIM is inserted !?! | MaRiN | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-29-2000 17:08 |
