Old 06-05-2008, 10:53   #1 (permalink)
Member: 676100
Sonork: 100.1577777
Thanks Meter: 18
""problem In Flashing Nokia 2626 Please Help Me""
I HAVE SOME PROBLEM IN FLASHING NOKIA 2626, THE FLASH PROCESS TAKE PLAYS BUT FINALLY WAITING PHONE TO BOOT FAILED, I HEREBY GIVE THE LOGS:-
JAF version 1.98.50
Detected PKEY: 9001141F
Card life counter: 93.36%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_03.080
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_03.08md
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh700_nai3.08aa
Languages in ppm: English,Filipino,Vietnamase
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_03.080
Booting phone...
Phone didn't answer with TX line high after UEM reset!
Causes:
1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line.
2.UEM damaged -> replace UEM.
MCU ID: 0xCCCC
This MCU ID is not supported in chosen flash file...
Error booting phone...
Backup IMEI zone...
Setting local mode...
Failed! Aborting!
Getting MCUID...
Causes:
MCU ID: 0xCCCC
Failed!!!
Booting phone...
Causes:
MCU ID: 0xCCCC
Cannot find boot file...
Backup IMEI zone...
Failed! Aborting!
Getting MCUID...
Causes:
MCU ID: 0xCCCC
Failed!!!
Powering the phone...
Failed! Aborting!
Backup IMEI zone...
Failed! Aborting!
Getting MCUID...
Causes:
MCU ID: 0xCCCC
Failed!!!
No ini files found...
Backup IMEI zone...
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\352770012195840_imei_back up_151556.rpl
Done!
Getting MCUID...
MCU ID: 0x3040
Reading flash chip detailes...
FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
MCU ID: 0x3040
Boot is ready...
Algo is ready...
Loader is ready...
Erasing area: 01000000 - 01FFFFFF...
Done!
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.ppm_ic
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.image_ic
Languages in ppm: English,Arabic,French,Swahili
CNT: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.image_ic
Booting phone...
MCU ID: 0x3040
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Flash ID is 0xE822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: c5
Loader is ready...
MSID: 8434B0A9928751125BCAADB823
MSID decoded: D26EBAF10006794EAA000610
FAID: A068743B5C4B11BB18891E8A
Operation took 0 minutes 12 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01B80000 - 01EDFFFF...
Operation took 0 minutes 23 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 11 seconds...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Extracting Content Pack...
Error setting local mode...
CP Extract Failed!
PPM: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.ppm_ic
Booting phone...
MCU ID: 0x3040
Boot size is 0x09A8
Boot is ready...
Loader size is 0x7528; Loader chk: 25
Loader is ready...
MSID: 843BB4680BD1D94CBE00DA1ADB
MSID decoded: 3E4EBAE90006794EA9000000
FAID: 118E9F9EAA2068EF41ABAA15
Erasing PPM...
Erasing area: 018E0000 - 01B7FFFF...
Operation took 0 minutes 19 seconds...
Writing...
Operation took 0 minutes 10 seconds...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 55 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
PLEASE HELP ME
Old 09-27-2008, 11:47   #2 (permalink)
Member: 682052
Thanks Meter: 8
6.80 flash yor mobile
Old 09-27-2008, 11:57   #3 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
Originally Posted by rajeevpchandran View Post
i have some problem in flashing nokia 2626, the flash process take plays but finally waiting phone to boot failed, i hereby give the logs:-
jaf version 1.98.50
detected pkey: 9001141f
card life counter: 93.36%
p-key nokia module version 01.02
detected jaf interface version: 01.b0, driver version: 40000, library version: 30112
jaf dct4/bb5 loaders dir: C:\program files\odeon\jaf\flash\
jaf dct4/bb5 product dir: C:\program files\nokia\phoenix\products\
jaf usb loaders dir: C:\program files\odeon\jaf\flashusb\
jaf dct3/dctl loaders dir: C:\program files\odeon\jaf\flash3\
files set for flashing:
Mcu flash file: None
ppm flash file: None
cnt flash file: None
adsp flash file: None
ape variant file: None
ape user flash file: None
ini file .ini is missing. Continue searching for second ini type...
Files set for flashing:
Mcu flash file: C:\program files\nokia\phoenix\products\rh-70\rh70_03.080
ppm flash file: C:\program files\nokia\phoenix\products\rh-70\rh70_03.08md
cnt flash file: C:\program files\nokia\phoenix\products\rh-70\rh700_nai3.08aa
languages in ppm: English,filipino,vietnamase
mcu: C:\program files\nokia\phoenix\products\rh-70\rh70_03.080
booting phone...
Phone didn't answer with tx line high after uem reset!
Causes:
1. Bsi line is not connected properly in connector -> check cable, also for 3.3k resistor in serial with bsi line.
2.uem damaged -> replace uem.
Mcu id: 0xcccc
this mcu id is not supported in chosen flash file...
Backup imei zone...
Failed! Aborting!
Getting mcuid...
Causes:
Mcu id: 0xcccc
failed!!!
Mcu: C:\program files\nokia\phoenix\products\rh-70\rh70_03.080
booting phone...
Causes:
Mcu id: 0xcccc
cannot find boot file...
Backup imei zone...
Failed! Aborting!
Getting mcuid...
Causes:
Mcu id: 0xcccc
failed!!!
Failed! Aborting!
Backup imei zone...
Failed! Aborting!
Getting mcuid...
Causes:
Mcu id: 0xcccc
failed!!!
no ini files found...
backup imei zone...
Reading imei...
Reading imei data...
Building rpl backup file...
C:\program files\odeon\jaf\progdata\352770012195840_imei_back up_151556.rpl
done!
Getting mcuid...
Mcu id: 0x3040
reading flash chip detailes...
Flash id0: 22e800ec <=> samsung (sec) -> k5g2829atc addr0: 0x01000000 - 0x01ffffff, sectorsize0: 10
flash id1: 00010000 <=> flash -> not used addr1: 0x02000000 - 0x02ffffff, sectorsize1: 0
first 16 bytes: Ad 7e b6 1a 1b be 0b e2 7d 58 6b e4 db ee 65 14
mcu id: 0x3040
boot is ready...
Algo is ready...
Loader is ready...
Erasing area: 01000000 - 01ffffff...
Done!
Mcu flash file: C:\program files\nokia\phoenix\products\rm-291\rm291__06.80.mcusw
ppm flash file: C:\program files\nokia\phoenix\products\rm-291\rm291__06.80.ppm_ic
cnt flash file: C:\program files\nokia\phoenix\products\rm-291\rm291__06.80.image_ic
languages in ppm: English,arabic,french,swahili
cnt: C:\program files\nokia\phoenix\products\rm-291\rm291__06.80.image_ic
booting phone...
Mcu id: 0x3040
boot file: C:\program files\odeon\jaf\flash\u3_2nd.fia
loader version: 04.46.01 -> revision: 0007
boot size is 0x09a8
boot is ready...
first 16 bytes: Ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
flash id is 0xe822ec00
flash loader is c:\program files\odeon\jaf\flash\u3_amd.fia
loader size is 0x7528; loader chk: C5
loader is ready...
msid: 8434b0a9928751125bcaadb823
msid decoded: D26ebaf10006794eaa000610
faid: A068743b5c4b11bb18891e8a
operation took 0 minutes 12 seconds...
Erasing content pack...
erasing area: 01b80000 - 01edffff...
Writing...
Perm. Data restore ok
operation took 0 minutes 11 seconds...
Restarting mcu...
Extracting content pack...
Cp extract failed!
Ppm: C:\program files\nokia\phoenix\products\rm-291\rm291__06.80.ppm_ic
booting phone...
Mcu id: 0x3040
boot size is 0x09a8
boot is ready...
loader size is 0x7528; loader chk: 25
loader is ready...
msid: 843bb4680bd1d94cbe00da1adb
msid decoded: 3e4ebae90006794ea9000000
faid: 118e9f9eaa2068ef41abaa15
Erasing ppm...
erasing area: 018e0000 - 01b7ffff...
Writing...
operation took 0 minutes 10 seconds...
Restarting mcu...
Flashing done!
Failed! Aborting!
Please help me
brother see this red maked area flashing not proper
u must full erase flash memory then flash muc+ppm+cnt
post result
Old 09-27-2008, 14:05   #4 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,266
first you full erassed & then flashed your phone will be 1000000000000000000% ok
Old 09-27-2008, 14:17   #5 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
""I want to unlock Nokia 6061 - please help me"" rajeevpchandran HWK 0 08-12-2008 13:57
""problem In Flashing Nokia 3230 Please Help Me"" rajeevpchandran Nokia Hardware & Hardware Repair 3 06-06-2008 09:06
""problem In Flashing Nokia 3230 Please Help Me"" rajeevpchandran J.A.F. By Jafsupport.com 0 06-03-2008 17:19
Page generated in 0.21006 seconds with 10 queries
