03-09-2009, 13:52 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | 2600c doesnot power ON on battery....but comes ON on device NORMAL MODE EXPERTIES HELP PLZ |
The Following User Says Thank You to cel_phon For This Useful Post: |
03-09-2009, 17:24 | #2 (permalink) |
Junior Member Join Date: Jan 2006
Member: 216616 Status: Offline Thanks Meter: 11 | dear if u do hardware and know what to do then i give u tip to check it. If so take a sharp twizer and short the easy cable jack both outer points with each other or make a jumper from inside with a thin wire then try to switch it on if it works ok then replace the charging jack it will work 100% but before replacing try to make hardware jumper first . waiting for ur reply SAAQI |
The Following User Says Thank You to saaqi For This Useful Post: |
09-03-2009, 16:17 | #8 (permalink) | |
Junior Member Join Date: Jul 2007 Location: BANGLADESH
Member: 553151 Status: Offline Thanks Meter: 1 | Quote:
3310/8250 can't on with batt but can turn on with flasher | TokeiLampin | Nokia Hardware & Hardware Repair | 14 | 08-05-2005 06:00 |
8250 can't on with batt but can turn on with flasher | TokeiLampin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-02-2005 01:08 |
3310 can't on with batt but can turn on with flasher | TokeiLampin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 05-28-2005 12:36 |
3410 can't turn on with battery but... | TELE-MEDIA | Nokia Hardware & Hardware Repair | 3 | 07-05-2004 11:39 |
8210 Turns ON when battery inserted & OFF on key press | Tsunami | Nokia Hardware & Hardware Repair | 4 | 10-28-2003 23:37 |
