02-27-2010, 11:19 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 303868 Status: Offline Thanks Meter: 62 | 2600c - key pad not work but incoming is ok I flash with latest ver & unlock by UB . Incoming & charging is OK . On/off switch worked . I rehot & wash it properly . but not ok |
02-27-2010, 11:35 | #2 (permalink) |
Freak Poster Join Date: Jun 2007 Location: banglore\kerala
Member: 523496 Status: Offline Sonork: ammachis Thanks Meter: 76 | change the keyboard and check once then chage with an original keypad ic be care full cpu is just near to the keypad ic al lthe best |
02-27-2010, 13:57 | #4 (permalink) |
Member: 303868 Status: Offline Thanks Meter: 62 | I read all 2600c thread and i am very upset . because all the complainer very hard labour on keypad problem but finaly maximan member cannot success in this job . because keypad is directly related with CPU . so it is main cause to maximam set can not repair . |
02-27-2010, 14:49 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: kurdistan
Member: 1167158 Status: Offline Thanks Meter: 1,723 | [QUOTE=sonu_to88;5492224]This set is water dammage set I flash with latest ver & unlock by UB . Incoming & charging is OK . On/off switch worked . change keypad ic |
2600c all key pad not work | shama | Nokia Hardware & Hardware Repair | 1 | 08-22-2009 14:31 |
i907 keypad not working but stylus is ok | dmaetrey | Samsung Hardware Repair | 0 | 12-16-2008 05:06 |
2600c key pad not work | hisham786 | Nokia Hardware & Hardware Repair | 2 | 07-16-2008 19:25 |
Nokia 3110c kye pad no work, but No Off OK | Mobile_plus | Nokia Hardware & Hardware Repair | 1 | 06-13-2008 06:46 |
Gd 92 key pad not working | GSM RAJ | Hardware Repair by brands | 1 | 12-13-2002 18:35 |
