Old 07-30-2009, 02:12   #1 (permalink)
nazrul islam's Avatar
Member: 756569
Thanks Meter: 185
2600c not on with battery
It was fall down and dead, I was re-hot and flash it, flash, ui setting, and normal mode ok, but not on with battery. if i try with power supply and press power key some response from it but not on, i think power switch is ok but other problem. Anybody please help me.
The Following User Says Thank You to nazrul islam For This Useful Post:
Old 07-30-2009, 07:25   #2 (permalink)
Member: 772941
Sonork: 112
Thanks Meter: 349
did you checkh charge? if charging ok try to change under keypad flex, if same problem just heat power ic.
Old 07-30-2009, 08:51   #3 (permalink)
Member: 978899
Sonork: ridhocell
Thanks Meter: 30
the same problem with my 6600....
normal mode oke with ufs, and respon to charging. but can't on with baterry. power switch OK...
try to heat power ic, and problem solve.
Old 07-30-2009, 09:23   #4 (permalink)
Member: 752828
some dct4+ phone is not on after flash because of unlocking so unlock it and try another battery .when unlock successful then post your result.
Old 07-30-2009, 17:20   #5 (permalink)
Member: 756569
Thanks Meter: 185
thanks you all. i well try and post resalt.
Old 07-30-2009, 20:55   #6 (permalink)
Member: 321730
Thanks Meter: 16
change to charging jack
N73 not on with battery mohammed-anis Nokia Hardware & Hardware Repair 8 09-06-2008 18:07
6600 power not on with battery plz help me amanhalwara Nokia Hardware & Hardware Repair 2 01-13-2008 19:33
6230 flash ok but not on with battery zeerik Nokia Digital Core Technology 4 ( DCT-4 ) 0 11-26-2007 09:54
6600 Not On With Battery Pl Help amanhalwara Nokia Hardware & Hardware Repair 1 10-27-2007 13:44
1100 not on with battery zeerik Nokia Digital Core Technology 4 ( DCT-4 ) 0 09-26-2007 13:28
Page generated in 0.13264 seconds with 9 queries
