05-26-2007, 09:14 | #10 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | Quote:
then rehot or reboll power supply ic if still the preblem same? change power ic | |
05-26-2007, 10:09 | #11 (permalink) |
No Life Poster Join Date: Mar 2007 Location: INDIA
Member: 463150 Status: Offline Thanks Meter: 91 | job done The problem of batt bar has been solved by flashing with lower version without re building IMEI. BUT NOW THE SET IS NOT GETTING NETWORK AND WHEN SEARCHING MANUALLY IA RESTARTS AFTER 5 TO 8 SECONDS.. WHATS THE SOLUTION FOR THIS |
05-26-2007, 12:24 | #13 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | Hi Friend, First of all, you REBUILD IMEI and after that do UI SETTINGS except START IN NORMAL MODE. See what happens. Next, if not solved Apply Little heat on COBBA, HAGAR and ON THE ANTENNA SWITCH and very little heat on THE PA. Post result. amit123 |
05-26-2007, 12:36 | #14 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: india Age: 40
Member: 101117 Status: Offline Thanks Meter: 466 | Quote:
then use ini.simlock,fullfatory,setfaid rebuild imei problem solved if its same u have to remove ram then by cleaning place it again if same replace ram post results | |
K 530 crazy batt bar !!!! | fasany | Sony Ericsson Hardware Repair | 1 | 01-29-2010 16:43 |
3310 low batt | thecult | Nokia Hardware & Hardware Repair | 19 | 06-17-2003 01:37 |
3330 powers off when 2 batt bars are left | m1dzb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 07-05-2002 00:25 |
3310 only two bar signal?????????? | tone | Nokia Hardware & Hardware Repair | 3 | 03-22-2002 19:40 |
3310 only one bar signal | tone | Nokia Hardware & Hardware Repair | 4 | 01-24-2002 09:42 |
