08-13-2008, 15:47 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: .::AZAD KASHMIR::.
Member: 681574 Status: Offline Sonork: 100.1614243 Thanks Meter: 138 | 2610 unlocking problem i write pm and flash with jaf ver. 3.77 and unlock but this error appear???? Getting MCU ID MCU ID: 0x3040 FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\353968012830486_imei_back up_1834138.rpl Done! Backup imei OK! MCU: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__04.51.mcusw Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: c5 Loader is ready... P-key nokia module version 01.02 MSID: 84BCE84349D521EBD6220BEFFE MSID decoded: 9A43BAE900144559A8000000 FAID: 1F59C9DAF6087EB2E49966CA Operation took 0 minutes 12 seconds... Erasing... Found 3 interval(s) to erase Erasing area: 01000000 - 0101FFFF... Erasing area: 01020000 - 018DFFFF... Erasing area: 01EE0000 - 01FDFFFF... Operation took 1 minutes 3 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 53 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__04.51.image_ia Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: c5 Loader is ready... P-key nokia module version 01.02 MSID: 842BA7360E08649D00E047FC10 MSID decoded: D26EBAF100144559AA000610 FAID: 78D02EF01D4D2B513F09E7E1 Operation took 0 minutes 12 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01B80000 - 01EDFFFF... Operation took 0 minutes 21 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 7 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Extracting Content Pack... Running: (c) Nokia File Server CNT Extract Skiped. Operation took 0 minutes 4 seconds... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__04.51.ppm_ia Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 25 Loader is ready... P-key nokia module version 01.02 MSID: 84B4BA3D3461A069E24FA93D16 MSID decoded: 3E4EBAE900144559A8000000 FAID: 1FB4C9DCA5E9D099479C9852 Operation took 0 minutes 12 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 018E0000 - 01B7FFFF... Operation took 0 minutes 16 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 11 seconds... Restarting MCU... Flashing Done! Operation took 3 minutes 42 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-86, Software version: 04.51 IMEI: 353968012830486 Product Code: 0533407 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 4 seconds... Done! Done! Done! Powering the phone... Unlocking... IMEI: 353968012830486 ASIC: b SW version: 04.51 Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__04.51.mcusw Decrypting flash...Done Checking ROM call...Done Checking security function...Done Patch status: 02 Error patching... any body help me???????????????????????? |
08-25-2008, 17:35 | #4 (permalink) |
Junior Member Join Date: Aug 2006
Member: 339548 Status: Offline Thanks Meter: 0 | i got the same problem.i use jaf 1.98.52 but version doesnt matter i guess.i do 2610s and 2626s and some of them i unlock without problems and some i cant. im wondering about what ive seen while unlockin succesfully.there was "can't make imei backup" everytime i did it and couldnt read info of the phone.there were no problems with patchin and unlockin.those i can read i cant unlock. maybe its a question of pms but only some of them we should remove,replace or back up and restore after job.?? |
2610 unlock problem | shami | MT-BOX | 6 | 04-23-2007 13:17 |
2610 unlock problem | ceedee | MT-BOX | 4 | 11-21-2006 07:43 |
2310 & 2610 Unlocking Problem With Ufs 3 | ..::: Naveed :::.. | UFS2 + UFS3-Tornadoflasher | 1 | 11-10-2006 10:26 |
Odia told to put 2610 unlock problem here ! | preshaust | UFS2 + UFS3-Tornadoflasher | 11 | 10-31-2006 13:23 |
