2626 charger not supported help me anyone hv any solution :rolleyes: |
First check the Battery and charging connector,most commenly problem is due to water damage,cleane the pcb |
pls use search button before make new post http://forum.gsmhosting.com/vbb/show...t=2626+charger http://forum.gsmhosting.com/vbb/show...t=2626+charger http://forum.gsmhosting.com/vbb/show...t=2626+charger br, flasherbox:) |
sir , iam not able to download the file from hwk support site, the error report is followed, plz help it is urgent Your account is temporarily blocked. You can find out the reason by asking our moderators on forum. For solving account issues please contact your reseller. Only your reseller can resolve this situation. Additional info: Server seed: attempt to download files from server seed using third-party tools! |
for 2626 charger not supported write good pm file in the phone nd post results regards kmax mobile |
2626 try to this ok i try and ok to 2626 |
any one having solution to 2626 charging solution any one having solution to 2626 charging solution... plz post with pic |
2626 charging not supported problem solv just change power IC and ur set ok u haue to write rpl ..........say thk |
http://www.4shared.com/file/83700693...arging-ok.html |
thxxxx bro! have a good time! |
jus write a good pm i have tested it 100% working |
2626 charging not support 2626 (ext) charging not support 1) Remove duel resistor above uem 2) write good pm this problem have been shortout by this 2 post |
thanks problem is solved by write good pm |
