08-07-2008, 12:50 | #1 (permalink) |
Registered User Join Date: Dec 2007 Location: krishnagiri
Member: 645764 Status: Offline Thanks Meter: 208 | 2626 phone restricted problem |
The Following User Says Thank You to ka jagan For This Useful Post: |
08-07-2008, 13:05 | #3 (permalink) | |
Freak Poster Join Date: Oct 2007 Location: Sydney (Australia) Age: 37
Member: 620594 Status: Offline Thanks Meter: 38 | Quote:
If you have already flash the phone than , just press unlock button, JAF will ask you for MCU file. put same MCU which you have flahed ( Remember : Same version . This is must. otherwise you will loose your phone ) Hardly. less than 1 minute procedure and your phone is unlock. Just try. | |
08-14-2008, 17:10 | #12 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 44
Member: 265133 Status: Offline Thanks Meter: 285 | i also have the same problem i flashed it with 6.80 version with JAF wrote gud pm ,did factory settings ,unlocked it but problem remains same board is clean no water damage or physical damage here is the log Powering the phone... Unlocking... IMEI: 358087015112100 ASIC: b SW version: 06.80 Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw Decrypting flash... Encrypting.... CHK Patch found - Unlock Patch found and are not in same block Patch status: 01 MCU ID: 0x3040 Algo is ready... P-key nokia module version 01.02 Erasing area: 010A0000 - 010BFFFF... Unlocking... Phone is not in LOCAL MODE or TEST MODE, or imei is damaged... Failed! Aborting! solutions please thank you |
6233 network problem pm write but phone restricted problem please help me | micro_hsr | Nokia Base Band 5 ( BB-5 ) | 4 | 10-23-2008 10:55 |
2626 phone restricted | ka jagan | Nokia Hardware & Hardware Repair | 11 | 05-18-2008 15:45 |
nokia3120 phone restricted problem | Adityaram | Nokia Hardware & Hardware Repair | 2 | 11-07-2007 11:02 |
