Old 09-01-2008, 09:43   #1 (permalink)
Member: 132070
Thanks Meter: 121
Thumbs up 2630 modif light ultimated solution
Just like 1110,etc modif light solution
convert from seri to pararell ways on led circuit
This solution is use for set with water damage problem
On only work if KDL ways not broken..cause need this way for led control.
this solution is convert led ways from Seri to Pararell like led ways on old nokia 3310/8210.
So after convert suply power to led become 3.6V like batt volt.
after make modification on board you must make some modification on LCD too..just like on board,just make it pararell
At last this solution is already TESTED by me
Use on You Own Risk!!!
File Type: jpg 2630 light modif ultimate solution.jpg (100.5 KB, 8026 views)
The Following 78 Users Say Thank You to INOVASI For This Useful Post:
Old 09-17-2008, 12:15   #2 (permalink)
RamSon83's Avatar
Member: 500637
Thanks Meter: 424
thnx for ur sharing but plz can you explaine more
Old 10-07-2008, 08:54   #3 (permalink)
sekar_k's Avatar
Member: 686254
Thanks Meter: 46
thnx for ur sharing but plz can you explaine charging ok but power not save
The Following User Says Thank You to sekar_k For This Useful Post:
Old 11-08-2008, 02:39   #4 (permalink)
DAVIESON OJO's Avatar
Member: 590041
Thanks Meter: 45
i have a very easy solution,that you dont need to remove anything; just two connection everything is ok.but friends i dont know how to prepare picture.if any body can help me on this i promise am going to share this solution because is 100% working and very easy
Old 11-08-2008, 22:35   #5 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
tell me ,i am able to make pic ,how i can help you ?
Rashid Ahmed Nadeem
The Following User Says Thank You to r a nadeem For This Useful Post:
Old 11-09-2008, 07:09   #6 (permalink)
Member: 590041
Thanks Meter: 45
i need the 2630 board picture ,the keypad picture and the screen back open picture.pls am counting on you
Old 11-09-2008, 19:19   #7 (permalink)
shahid74's Avatar
Member: 737862
Thanks Meter: 41
chang thavo ic slow charging problem
Old 11-09-2008, 19:22   #8 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
" bro which set do u mean do u plz add more information, thanx"
The Following User Says Thank You to mobilespeed For This Useful Post:
Old 11-09-2008, 22:50   #9 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
here is board of 2630, go ahead
Rashid Ahmed Nadeem
The Following 9 Users Say Thank You to r a nadeem For This Useful Post:
Old 11-10-2008, 07:56   #10 (permalink)
Member: 590041
Thanks Meter: 45
thank u very much.u keep to ur words but one more thing i need the keypad picture and the screen back open.pls how can i do this by myself incase of next time.i have so many solution but i dont know how u guys get picture.thank you
The Following User Says Thank You to DAVIESON OJO For This Useful Post:
Old 11-11-2008, 08:32   #11 (permalink)
Member: 765659
Thanks Meter: 20
thanksssssss my brth
The Following User Says Thank You to mobilehouse29 For This Useful Post:
Old 11-11-2008, 21:34   #12 (permalink)
Member: 590041
Thanks Meter: 45
Arrow easy 2630 backlight solution
100% solution for 2630 backlight.follow instructure carefully and use THANKS button if pleased
The Following 17 Users Say Thank You to DAVIESON OJO For This Useful Post:
Old 11-12-2008, 04:50   #13 (permalink)
sood's Avatar
Member: 812373
Thanks Meter: 47
good job .............................
Old 12-13-2008, 18:50   #14 (permalink)
..::My3gtech::..'s Avatar
Member: 158032
Thanks Meter: 331
Any one test this solution with sucess please reply......
Omairbutt786
Old 12-13-2008, 19:58   #15 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
Arrow
No brother i think not good solution
The Following User Says Thank You to /\/\A/\/| For This Useful Post:
2630 modif light solution vinay_sharma Nokia Hardware & Hardware Repair 3 12-22-2008 17:05
..:: 2630 modif light ultimated solution ::.. waji mobiles Nokia Hardware & Hardware Repair 6 11-08-2008 02:50
» 2630 light modif ultimate solution bgreat Nokia Hardware & Hardware Repair 1 10-19-2008 14:48
2630 no light himanshu taldar Nokia Hardware & Hardware Repair 4 09-17-2008 12:25
Nokai 2630 No Light On Display ohio Nokia Hardware & Hardware Repair 3 07-25-2008 17:47
Page generated in 0.23066 seconds with 10 queries
