GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Nokia Hardware & Hardware Repair (https://forum.gsmhosting.com/vbb/f148/)
-   -   2630 urgent (https://forum.gsmhosting.com/vbb/f148/2630-urgent-555743/)
asifalimass 06-24-2008 16:57
2630 urgent
hi nokia 2630 blue display problem ., any one plz tell solution;)
mobi4u 06-24-2008 17:36
i have problem 2630 very slow n e 1 can plz tell me the slution
manyosa 06-25-2008 14:08
Have you tried to test it with another display.
manyosa 06-25-2008 14:10
Try to restore setting use jaf if still full flash it.
asifalimass 06-25-2008 14:46
2630
yes i tried with a working display
ArtC 07-08-2008 18:04
got the same problem anybody can help
CHAPRAN 08-01-2008 08:25
Originally Posted by manyosa (Post 3426189)
try To Restore Setting Use Jaf If Still Full Flash It.
Try Flash It And Set Fell Seting.....but Same Problam Phone Slow
GsmGalant 08-01-2008 08:31
If is software problem, try to read full Pm from another phone and write it then fllash and full ul setings.
psilva 12-03-2008 20:08
hi
i do all of these things but not working i need solution please anyone give me the solution please .
best regards
crazytel
manibul 12-03-2008 20:20
You can change crystal clock if not ok you can change UPP i know this is very hard work.Thanks
jawwad 12-03-2008 20:44
if display shows blue light only,i can surely say only light circuit is working and single or more wires are damaged from LCD flex or from main board conector
psilva 12-03-2008 20:48
thank's friends for help
regards
crazytel
PANTECH N B R 01-08-2009 17:55
2630 blue display solution
1.display change checking
2.vio pin - 3
3.vflash pin - 22
4.connector replace
5.upp reboll
Page generated in 0.11532 seconds with 6 queries
