09-30-2009, 07:08 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: IN GSM WORLD Age: 45
Member: 959013 Status: Offline Thanks Meter: 262 | 2630 ver.57.xx network problem b.r |
12-15-2009, 10:03 | #3 (permalink) | |
Freak Poster Join Date: Apr 2007
Member: 493402 Status: Offline Thanks Meter: 34 | Quote:
if 2630 v 5720 is downgrade in jaf the problem is no signal and bluetooth just flash 2630 at v 57.20 and unlock it at cyclone.. 100% tested.. that 2630 v 57.20 is not supported at jaf, only the new update of cyclone can fix the signal just click unlock, make sure that the version is stil 57.20.. | |
12-15-2009, 14:13 | #4 (permalink) |
No Life Poster Join Date: Jan 2005 Location: at work
Member: 112112 Status: Offline Sonork: 100.1621373 Thanks Meter: 238 | hi br i nid pm for this version nokia 2630 v57.20 thanks and i am whaiting |
The Following User Says Thank You to zeroualot_7 For This Useful Post: |
12-16-2009, 12:19 | #6 (permalink) |
Freak Poster Join Date: Jul 2006 Location: india
Member: 306087 Status: Offline Thanks Meter: 24 | Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Failed to read info -> Phone not detected Booting UPP... UPP ID: 3168 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00EC2208 @ 0x01000000, Samsung, SectorSize: 128kB, Ext: 00009121 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2208 (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V Terminating flash session Boot operation took 6.437s Check Flashing Bus finished Failed to read info -> Phone not detected Booting UPP... UPP ID: 3168 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00EC2208 @ 0x01000000, Samsung, SectorSize: 128kB, Ext: 00009121 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2208 (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V Terminating flash session Boot operation took 6.110s Check Flashing Bus finished MCU Version V 57.20 MCU Date 09-02-09 Product RM-298 Manufacturer (c) Nokia IMEI 356065036065822 Mastercode 652171231 Selecting unlock method... Using Super DCT4 Activation Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-298_V 57.20.sunlock_img Writing patch file... Booting UPP... UPP ID: 3168 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00EC2208 @ 0x01000000, Samsung, SectorSize: 128kB, Ext: 00009121 FlashChip[1]: 0x00EC2208 @ 0x02000000, Samsung, SectorSize: 128kB, Ext: 00009121 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2208 (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V MSID-Crypted: 846131D0AD99D9A69A9749992F MSID-Plain: 2C40BAE9005A0D59A9000000 FAID-Crypted: DF73388D411248580C424271 Flashbus Write baud set to 6.50Mbits 4 Region(s) to erase Erasing NOR Region [0x013E0000-0x013FFFFF] Erasing NOR Region [0x01480000-0x0149FFFF] Erasing NOR Region [0x016C0000-0x016DFFFF] Erasing NOR Region [0x01C20000-0x01C3FFFF] Erase taken 1.375s Writing 32 blocks... Sending Super DCT4 Emulator... Emulator sent OK! All blocks written OK! Time taken 17.297s Terminating flash session Box VPP disabled Asic 11 HW Signature BCE88DFC093760E2 Simlock Server SIMLOCK SERVER Simlock Key 2341500000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553560650360658200 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23415F Asking card to sign HW Signature... Signed OK (12DF9F6DF6B264B449944B8A3804B413F87979B1) Simlock Security - UNKNOWN Writing SP... New SP Accepted OK! Phone unlocked OK! |
The Following User Says Thank You to pawansingh For This Useful Post: |
2630 vers 57.20 unlock problem | ..::GsmHelp::.. | Cyclonebox | 5 | 10-18-2009 17:47 |
anyone unlock 2630 ver.57.20 by code | safvanp | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 09-04-2009 14:12 |
can i unlocjk 2630 ver 57.20 | ikram tabassum1 | Cyclonebox | 7 | 08-29-2009 07:01 |
2630 ver 57.20 no signal after unlock | neo_urbon | Universalbox | 1 | 07-22-2009 20:37 |
