Old 01-28-2009, 10:04   #1 (permalink)
Member: 597471
Thanks Meter: 4
2680s-2 RM-392 NO NETWORK ACCESS
PLS.help to my 2680s-2..v.4.56 openline but no network Ive tried to write good pm file and flash to higher version the phone will dead or no power and i just flash back the v4.56 its ok again the problems is still no network...pls those have picture or image of network solution pls help us....i need the solution urgentlly...thanks....
Old 01-28-2009, 10:06   #2 (permalink)
shaikh_zubin's Avatar
Member: 461699
Thanks Meter: 80
u chek in manual ?????? what is manual error???
Old 01-28-2009, 10:11   #3 (permalink)
Member: 597471
Thanks Meter: 4
the imei start by number 3563xxxxxxxxx
if i do manual search ive seen the three network then if i select the network that i chose no network access appeared......sir..
Old 01-28-2009, 10:17   #4 (permalink)
Member: 461699
Thanks Meter: 80
so erase then flash latest firmware n unlock then u seting. if not done then hit on network section n reply fast.....
The Following User Says Thank You to shaikh_zubin For This Useful Post:
Old 01-28-2009, 10:47   #5 (permalink)
Member: 597471
Thanks Meter: 4
if flash to v5.28 failed aborting.......
do to unlock...here the logs...
Powering the phone...
Writing PM...
Field: 1, Record: 0, Len: 120->OK
Field: 1, Record: 2, Len: 90->OK
Field: 1, Record: 4, Len: 110->OK
Field: 1, Record: 6, Len: 90->OK
Field: 1, Record: 11, Len: 2->OK
Field: 1, Record: 12, Len: 2->OK
Field: 2, Record: 0, Len: 440->OK
Field: 4, Record: 1, Len: 16->OK
Field: 4, Record: 3, Len: 10->OK
Field: 4, Record: 4, Len: 8->OK
Field: 4, Record: 5, Len: 8->OK
Field: 4, Record: 6, Len: 8->OK
Field: 4, Record: 9, Len: 5->OK
Field: 4, Record: 16, Len: 4->OK
Field: 4, Record: 17, Len: 8->OK
Field: 4, Record: 18, Len: 80->OK
Field: 4, Record: 19, Len: 4->OK
Field: 4, Record: 28, Len: 2->OK
Field: 7, Record: 0, Len: 4->OK
Field: 7, Record: 1, Len: 32->OK
Field: 7, Record: 2, Len: 4->OK
Field: 8, Record: 0, Len: 2->OK
Field: 8, Record: 1, Len: 16->OK
Field: 8, Record: 2, Len: 16->OK
Field: 8, Record: 3, Len: 128->OK
Field: 8, Record: 4, Len: 128->OK
Field: 8, Record: 8, Len: 8->OK
Field: 8, Record: 9, Len: 8->OK
Field: 8, Record: 10, Len: 24->OK
Field: 11, Record: 0, Len: 4->OK
Field: 11, Record: 1, Len: 4->OK
Field: 11, Record: 2, Len: 4->OK
Field: 11, Record: 3, Len: 4->OK
Field: 11, Record: 4, Len: 1->OK
Field: 11, Record: 5, Len: 6->OK
Field: 11, Record: 6, Len: 2->OK
Field: 11, Record: 7, Len: 1->OK
Field: 11, Record: 8, Len: 1->OK
Field: 11, Record: 9, Len: 1->OK
Field: 11, Record: 10, Len: 1->OK
Field: 11, Record: 11, Len: 1->OK
Field: 11, Record: 12, Len: 1->OK
Field: 11, Record: 13, Len: 1->OK
Field: 11, Record: 14, Len: 2->OK
Field: 11, Record: 15, Len: 2->OK
Field: 11, Record: 16, Len: 2->OK
Field: 11, Record: 17, Len: 2->OK
Field: 11, Record: 18, Len: 16->OK
Field: 11, Record: 19, Len: 32->OK
Field: 11, Record: 20, Len: 32->OK
Field: 11, Record: 21, Len: 2->OK
Field: 11, Record: 22, Len: 2->OK
Field: 11, Record: 23, Len: 2->OK
Field: 11, Record: 24, Len: 2->OK
Field: 11, Record: 25, Len: 2->OK
Field: 11, Record: 26, Len: 2->OK
Field: 11, Record: 27, Len: 2->OK
Field: 11, Record: 28, Len: 2->OK
Field: 11, Record: 29, Len: 2->OK
Field: 11, Record: 30, Len: 2->OK
Field: 11, Record: 31, Len: 2->OK
Field: 11, Record: 32, Len: 2->OK
Field: 11, Record: 33, Len: 2->OK
Field: 11, Record: 34, Len: 2->OK
Field: 11, Record: 35, Len: 2->OK
Field: 11, Record: 36, Len: 2->OK
Field: 11, Record: 37, Len: 2->OK
Field: 11, Record: 38, Len: 2->OK
Field: 11, Record: 39, Len: 2->OK
Field: 11, Record: 40, Len: 2->OK
Field: 11, Record: 41, Len: 2->OK
Field: 11, Record: 42, Len: 2->OK
Field: 11, Record: 43, Len: 2->OK
Field: 11, Record: 44, Len: 2->OK
Field: 11, Record: 45, Len: 2->OK
Field: 11, Record: 46, Len: 2->OK
Field: 11, Record: 47, Len: 2->OK
Field: 11, Record: 48, Len: 2->OK
Field: 11, Record: 49, Len: 2->OK
Field: 11, Record: 50, Len: 2->OK
Field: 11, Record: 51, Len: 2->OK
Field: 11, Record: 52, Len: 2->OK
Field: 11, Record: 53, Len: 2->OK
Field: 11, Record: 54, Len: 2->OK
Field: 11, Record: 55, Len: 2->OK
Field: 11, Record: 56, Len: 2->OK
Field: 11, Record: 57, Len: 2->OK
Field: 11, Record: 58, Len: 2->OK
Field: 11, Record: 59, Len: 2->OK
Field: 11, Record: 60, Len: 2->OK
Field: 11, Record: 61, Len: 2->OK
Field: 11, Record: 62, Len: 2->OK
Field: 11, Record: 63, Len: 2->OK
Field: 11, Record: 64, Len: 2->OK
Field: 11, Record: 65, Len: 2->OK
Field: 11, Record: 66, Len: 4->OK
Field: 11, Record: 67, Len: 1->OK
Field: 11, Record: 68, Len: 4->OK
Field: 11, Record: 69, Len: 4->OK
Field: 11, Record: 70, Len: 4->OK
Field: 11, Record: 71, Len: 4->OK
Field: 11, Record: 72, Len: 16->OK
Field: 11, Record: 73, Len: 4->OK
Field: 11, Record: 74, Len: 2->OK
Field: 11, Record: 75, Len: 13->OK
Field: 12, Record: 0, Len: 102->OK
Field: 13, Record: 0, Len: 1->OK
Field: 13, Record: 1, Len: 2->OK
Field: 13, Record: 2, Len: 1->OK
Field: 13, Record: 3, Len: 2->OK
Field: 13, Record: 4, Len: 1->OK
Field: 13, Record: 5, Len: 1->OK
Field: 13, Record: 6, Len: 1->OK
Field: 13, Record: 7, Len: 1->OK
Field: 13, Record: 8, Len: 2->OK
Field: 13, Record: 9, Len: 1->OK
Field: 13, Record: 10, Len: 1->OK
Field: 13, Record: 11, Len: 48->OK
Field: 13, Record: 12, Len: 4->OK
Field: 13, Record: 13, Len: 1->OK
Field: 13, Record: 14, Len: 1->OK
Field: 13, Record: 15, Len: 886->OK
Field: 13, Record: 16, Len: 2->OK
Field: 13, Record: 17, Len: 1->OK
Field: 13, Record: 18, Len: 1->OK
Field: 13, Record: 19, Len: 8->OK
Field: 13, Record: 20, Len: 1->OK
Field: 13, Record: 21, Len: 1->OK
Field: 13, Record: 22, Len: 1->OK
Field: 13, Record: 23, Len: 1->OK
Field: 13, Record: 24, Len: 1->OK
Field: 13, Record: 25, Len: 2->OK
Field: 13, Record: 26, Len: 1->OK
Field: 13, Record: 27, Len: 1->OK
Field: 13, Record: 28, Len: 1->OK
Field: 13, Record: 29, Len: 1->OK
Field: 13, Record: 30, Len: 1->OK
Field: 13, Record: 31, Len: 1->OK
Field: 13, Record: 32, Len: 1->OK
Field: 13, Record: 33, Len: 1->OK
Field: 13, Record: 34, Len: 1->OK
Field: 13, Record: 35, Len: 1->OK
Field: 13, Record: 36, Len: 1->OK
Field: 13, Record: 37, Len: 4->OK
Field: 13, Record: 38, Len: 1->OK
Field: 13, Record: 39, Len: 1->OK
Field: 13, Record: 40, Len: 1->OK
Field: 13, Record: 41, Len: 1->OK
Field: 13, Record: 42, Len: 4->OK
Field: 13, Record: 43, Len: 4->OK
Field: 13, Record: 44, Len: 1->OK
Field: 13, Record: 45, Len: 4->OK
Field: 13, Record: 46, Len: 4->OK
Field: 13, Record: 47, Len: 1->OK
Field: 13, Record: 48, Len: 4->OK
Field: 13, Record: 49, Len: 1->OK
Field: 13, Record: 50, Len: 1->OK
Field: 13, Record: 51, Len: 1->OK
Field: 13, Record: 52, Len: 2->OK
Field: 13, Record: 53, Len: 4->OK
Field: 13, Record: 54, Len: 4->OK
Field: 13, Record: 55, Len: 1->OK
Field: 13, Record: 56, Len: 1->OK
Field: 13, Record: 57, Len: 1->OK
Field: 13, Record: 58, Len: 2->OK
Field: 13, Record: 59, Len: 1->OK
Field: 13, Record: 60, Len: 4->OK
Field: 13, Record: 61, Len: 4->OK
Field: 13, Record: 62, Len: 1->OK
Field: 13, Record: 63, Len: 4->OK
Field: 13, Record: 64, Len: 4->OK
Field: 13, Record: 65, Len: 1->OK
Field: 13, Record: 66, Len: 4->OK
Field: 13, Record: 67, Len: 4->OK
Field: 13, Record: 68, Len: 1->OK
Field: 13, Record: 69, Len: 1->OK
Field: 13, Record: 70, Len: 1->OK
Field: 13, Record: 71, Len: 4->OK
Field: 13, Record: 72, Len: 4->OK
Field: 13, Record: 73, Len: 1->OK
Field: 13, Record: 74, Len: 4->OK
Field: 13, Record: 75, Len: 2->OK
Field: 13, Record: 76, Len: 2->OK
Field: 13, Record: 77, Len: 2->OK
Field: 13, Record: 78, Len: 1->OK
Field: 13, Record: 79, Len: 1->OK
Field: 13, Record: 80, Len: 1->OK
Field: 13, Record: 81, Len: 1->OK
Field: 13, Record: 82, Len: 1->OK
Field: 13, Record: 83, Len: 2->OK
Field: 13, Record: 84, Len: 1->OK
Field: 13, Record: 85, Len: 4->OK
Field: 13, Record: 86, Len: 4->OK
Field: 13, Record: 87, Len: 2->OK
Field: 13, Record: 88, Len: 1->OK
Field: 13, Record: 89, Len: 4->OK
Field: 13, Record: 90, Len: 4->OK
Field: 13, Record: 91, Len: 2->OK
Field: 13, Record: 92, Len: 1->OK
Field: 13, Record: 93, Len: 4->OK
Field: 13, Record: 94, Len: 4->OK
Field: 13, Record: 95, Len: 2->OK
Field: 13, Record: 96, Len: 1->OK
Field: 13, Record: 97, Len: 4->OK
Field: 13, Record: 98, Len: 4->OK
Field: 13, Record: 99, Len: 2->OK
Field: 13, Record: 100, Len: 4->OK
Field: 13, Record: 101, Len: 2->OK
Field: 13, Record: 102, Len: 1->OK
Field: 13, Record: 103, Len: 4->OK
Field: 13, Record: 104, Len: 4->OK
Field: 13, Record: 105, Len: 4->OK
Field: 13, Record: 106, Len: 4->OK
Field: 13, Record: 107, Len: 4->OK
Field: 13, Record: 108, Len: 2->OK
Field: 13, Record: 109, Len: 4->OK
Field: 13, Record: 110, Len: 4->OK
Field: 13, Record: 111, Len: 4->OK
Field: 13, Record: 112, Len: 2->OK
Field: 13, Record: 113, Len: 4->OK
Field: 13, Record: 114, Len: 4->OK
Field: 13, Record: 115, Len: 1->OK
Field: 13, Record: 116, Len: 1->OK
Field: 13, Record: 117, Len: 1->OK
Field: 13, Record: 118, Len: 4->OK
Field: 13, Record: 119, Len: 4->OK
Field: 13, Record: 120, Len: 1->OK
Field: 13, Record: 121, Len: 1->OK
Field: 13, Record: 122, Len: 1->OK
Field: 13, Record: 123, Len: 8->OK
Field: 13, Record: 124, Len: 1->OK
Field: 13, Record: 125, Len: 1->OK
Field: 13, Record: 126, Len: 1->OK
Field: 13, Record: 127, Len: 1->OK
Field: 13, Record: 128, Len: 1->OK
Field: 13, Record: 129, Len: 4->OK
Field: 13, Record: 130, Len: 4->OK
Field: 13, Record: 131, Len: 1->OK
Field: 13, Record: 132, Len: 1->OK
Field: 13, Record: 133, Len: 2->OK
Field: 13, Record: 134, Len: 1->OK
Field: 13, Record: 135, Len: 2->OK
Field: 13, Record: 136, Len: 1->OK
Field: 13, Record: 137, Len: 1->OK
Field: 13, Record: 138, Len: 4->OK
Field: 13, Record: 139, Len: 4->OK
Field: 13, Record: 140, Len: 1->OK
Field: 13, Record: 141, Len: 1->OK
Field: 13, Record: 142, Len: 1->OK
Field: 13, Record: 143, Len: 1->OK
Field: 13, Record: 144, Len: 4->OK
Field: 13, Record: 145, Len: 8->OK
Field: 13, Record: 146, Len: 4->OK
Field: 13, Record: 147, Len: 4->OK
Field: 13, Record: 148, Len: 1->OK
Field: 13, Record: 149, Len: 1->OK
Field: 13, Record: 150, Len: 1->OK
Field: 13, Record: 151, Len: 1->OK
Field: 13, Record: 152, Len: 1->OK
Field: 13, Record: 153, Len: 1->OK
Field: 13, Record: 154, Len: 1->OK
Field: 13, Record: 155, Len: 1->OK
Field: 13, Record: 156, Len: 1->OK
Field: 13, Record: 157, Len: 1->OK
Field: 13, Record: 158, Len: 1->OK
Field: 13, Record: 159, Len: 2->OK
Field: 13, Record: 160, Len: 2->OK
Field: 13, Record: 161, Len: 1->OK
Field: 13, Record: 162, Len: 1->OK
Field: 13, Record: 163, Len: 1->OK
Field: 13, Record: 164, Len: 1->OK
Field: 13, Record: 165, Len: 1->OK
Field: 13, Record: 166, Len: 1->OK
Field: 42, Record: 0, Len: 2->OK
Field: 42, Record: 1, Len: 12->OK
Field: 42, Record: 2, Len: 36->OK
Field: 42, Record: 3, Len: 36->OK
Field: 42, Record: 4, Len: 36->OK
Field: 42, Record: 5, Len: 36->OK
Field: 42, Record: 6, Len: 36->OK
Field: 42, Record: 7, Len: 40->OK
Field: 42, Record: 8, Len: 40->OK
Field: 42, Record: 9, Len: 40->OK
Field: 42, Record: 10, Len: 40->OK
Field: 42, Record: 11, Len: 40->OK
Field: 42, Record: 12, Len: 40->OK
Field: 42, Record: 13, Len: 40->OK
Field: 42, Record: 14, Len: 40->OK
Field: 44, Record: 0, Len: 1->OK
Field: 46, Record: 0, Len: 8->OK
Field: 50, Record: 0, Len: 2->OK
Field: 54, Record: 0, Len: 2->OK
Field: 65, Record: 0, Len: 11->OK
Field: 65, Record: 1, Len: 11->OK
Field: 65, Record: 2, Len: 11->OK
Field: 65, Record: 3, Len: 11->OK
Field: 65, Record: 4, Len: 11->OK
Field: 66, Record: 0, Len: 401->OK
Field: 66, Record: 1, Len: 240->OK
Field: 66, Record: 2, Len: 240->OK
Field: 66, Record: 3, Len: 1->OK
Field: 66, Record: 4, Len: 1->OK
Field: 66, Record: 5, Len: 240->OK
Field: 66, Record: 6, Len: 4->OK
Field: 66, Record: 7, Len: 4->OK
Field: 66, Record: 8, Len: 4->OK
Field: 66, Record: 9, Len: 4->OK
Field: 66, Record: 10, Len: 120->OK
Field: 66, Record: 11, Len: 240->OK
Field: 66, Record: 12, Len: 1->OK
Field: 66, Record: 53, Len: 1->OK
Field: 66, Record: 64, Len: 4->OK
Field: 66, Record: 65, Len: 4->OK
Field: 66, Record: 66, Len: 4->OK
Field: 66, Record: 67, Len: 4->OK
Field: 66, Record: 81, Len: 4->OK
Field: 66, Record: 82, Len: 4->OK
Field: 66, Record: 83, Len: 4->OK
Field: 66, Record: 85, Len: 80->OK
Field: 66, Record: 86, Len: 6400->OK
Field: 66, Record: 87, Len: 400->OK
Field: 66, Record: 88, Len: 60->OK
Field: 66, Record: 96, Len: 7232->OK
Field: 66, Record: 104, Len: 3->OK
Field: 66, Record: 105, Len: 3->OK
Field: 66, Record: 106, Len: 3->OK
Field: 66, Record: 108, Len: 160->OK
Field: 66, Record: 111, Len: 40->OK
Field: 66, Record: 113, Len: 1->OK
Field: 88, Record: 0, Len: 36->OK
Field: 96, Record: 0, Len: 2->OK
Field: 96, Record: 1, Len: 20->OK
Field: 107, Record: 0, Len: 21->OK
Field: 107, Record: 1, Len: 89->OK
Field: 107, Record: 2, Len: 69->OK
Field: 107, Record: 3, Len: 70->OK
Field: 107, Record: 25, Len: 132->OK
Field: 107, Record: 26, Len: 12->OK
Field: 116, Record: 0, Len: 2->OK
Field: 116, Record: 1, Len: 12->OK
Field: 116, Record: 2, Len: 36->OK
Field: 116, Record: 3, Len: 36->OK
Field: 116, Record: 4, Len: 36->OK
Field: 116, Record: 5, Len: 36->OK
Field: 116, Record: 6, Len: 36->OK
Field: 116, Record: 7, Len: 40->OK
Field: 116, Record: 8, Len: 40->OK
Field: 116, Record: 9, Len: 40->OK
Field: 116, Record: 10, Len: 40->OK
Field: 116, Record: 11, Len: 40->OK
Field: 116, Record: 12, Len: 40->OK
Field: 116, Record: 13, Len: 40->OK
Field: 116, Record: 14, Len: 40->OK
Field: 116, Record: 15, Len: 40->OK
Field: 116, Record: 16, Len: 40->OK
Field: 120, Record: 0, Len: 2550->Error: Need auth..
Field: 120, Record: 1, Len: 510->Error: Need auth..
Field: 120, Record: 2, Len: 510->Error: Need auth..
Field: 120, Record: 3, Len: 510->Error: Need auth..
Field: 193, Record: 2, Len: 8->OK
Field: 193, Record: 3, Len: 32->OK
Field: 193, Record: 4, Len: 32->OK
Field: 193, Record: 9, Len: 64->OK
Field: 208, Record: 0, Len: 40->OK
Field: 217, Record: 0, Len: 32->OK
Field: 218, Record: 0, Len: 2->OK
Field: 232, Record: 0, Len: 20->OK
Field: 232, Record: 2, Len: 1->OK
Field: 232, Record: 3, Len: 1->OK
Field: 238, Record: 1, Len: 1->OK
Field: 239, Record: 0, Len: 2->OK
Field: 239, Record: 1, Len: 2314->OK
Field: 239, Record: 2, Len: 2314->OK
Field: 250, Record: 1, Len: 1932->OK
Field: 250, Record: 2, Len: 128->OK
Field: 250, Record: 3, Len: 652->OK
Field: 250, Record: 4, Len: 36->OK
Field: 301, Record: 0, Len: 2->OK
Field: 301, Record: 1, Len: 12->OK
Field: 301, Record: 2, Len: 36->OK
Field: 301, Record: 3, Len: 36->OK
Field: 301, Record: 4, Len: 36->OK
Field: 301, Record: 5, Len: 36->OK
Field: 301, Record: 6, Len: 36->OK
Field: 301, Record: 7, Len: 40->OK
Field: 301, Record: 8, Len: 40->OK
Field: 301, Record: 9, Len: 40->OK
Field: 301, Record: 10, Len: 40->OK
Field: 301, Record: 11, Len: 40->OK
Field: 301, Record: 12, Len: 40->OK
Field: 301, Record: 13, Len: 40->OK
Field: 301, Record: 14, Len: 40->OK
Field: 301, Record: 15, Len: 40->OK
Field: 301, Record: 16, Len: 40->OK
Field: 308, Record: 0, Len: 1->OK
Field: 308, Record: 5, Len: 10->OK
Field: 308, Record: 6, Len: 1->OK
Field: 308, Record: 7, Len: 1->OK
Field: 308, Record: 8, Len: 1->OK
Field: 308, Record: 9, Len: 40->OK
Field: 322, Record: 0, Len: 1->OK
Field: 334, Record: 0, Len: 1->OK
Field: 354, Record: 0, Len: 15->OK
Field: 355, Record: 1, Len: 4028->OK
Field: 362, Record: 0, Len: 255->Error: Need auth..
Field: 362, Record: 1, Len: 510->Error: Need auth..
Field: 364, Record: 0, Len: 2->OK
Field: 364, Record: 1, Len: 12->OK
Field: 364, Record: 2, Len: 36->OK
Field: 364, Record: 3, Len: 36->OK
Field: 364, Record: 4, Len: 36->OK
Field: 364, Record: 5, Len: 36->OK
Field: 364, Record: 6, Len: 36->OK
Field: 364, Record: 7, Len: 40->OK
Field: 364, Record: 8, Len: 40->OK
Field: 364, Record: 9, Len: 40->OK
Field: 364, Record: 10, Len: 40->OK
Field: 364, Record: 11, Len: 40->OK
Field: 364, Record: 12, Len: 40->OK
Field: 364, Record: 13, Len: 40->OK
Field: 364, Record: 14, Len: 40->OK
Field: 365, Record: 0, Len: 2->OK
Field: 365, Record: 1, Len: 12->OK
Field: 365, Record: 2, Len: 36->OK
Field: 365, Record: 3, Len: 36->OK
Field: 365, Record: 4, Len: 36->OK
Field: 365, Record: 5, Len: 36->OK
Field: 365, Record: 6, Len: 36->OK
Field: 365, Record: 7, Len: 40->OK
Field: 365, Record: 8, Len: 40->OK
Field: 365, Record: 9, Len: 40->OK
Field: 365, Record: 10, Len: 40->OK
Field: 365, Record: 11, Len: 40->OK
Field: 365, Record: 12, Len: 40->OK
Field: 365, Record: 13, Len: 40->OK
Field: 365, Record: 14, Len: 40->OK
Done!
Unlocking...
IMEI: 356390020932708
ASIC: b
SW version: 04.56
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__04.56.mcusw
Decrypting flash...Done
Checking ROM call...Done
Checking security function...Done
Encrypting....Done
Patch status: 00
MCU ID: 0x3162
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
FLASH ID0: 317E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
FLASH ID1: 317E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11
First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00
Flash ID is 0x7E310100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: a2
Loader is ready...
P-key nokia module version 01.02
MSID: 84AF861DB4A73279C78FACC2BD
MSID decoded: 2C40BAE9009218A9AA000000
FAID: 3E8444A609A6F2D171CCF989
Erasing area: 01000000 - 0101FFFF...
Erasing area: 01080000 - 0109FFFF...
Perm. Data Restore OK
Unlocking...
Failed! Aborting!
Failed! Aborting!
Old 01-28-2009, 10:56   #6 (permalink)
Member: 461699
Thanks Meter: 80
bro u have to erase first .
[email protected]
Old 01-29-2009, 00:09   #7 (permalink)
Member: 597471
Thanks Meter: 4
these is the error if try to erase flash sir,........
JAF version 1.98.61
Detected PKEY: chrizzz28
Card life counter: 91.46%
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
Backup IMEI zone...
Setting local mode...
Failed! Aborting!
Getting MCUID...
Phone didn't answer with TX line high after power on!
Causes:
1. Phone don't power on -> Check cable
2. TX pin from phone don't make contact -> Check cable
3. UPP damaged -> change UPP
MCU ID: 0xAAAA
Failed!!!
my cable working 100%
Old 01-29-2009, 01:15   #8 (permalink)
Member: 597471
Thanks Meter: 4
here the other logs...
JAF version 1.98.61
Detected PKEY: 9000BE1A
Card life counter: 91.23%
Backup IMEI zone...
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\356390020932708_imei_back up_846291.rpl
Done!
Getting MCUID...
MCU ID: 0x3162
Reading flash chip detailes...
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
MCU ID: 0x3162
Boot is ready...
Algo is ready...
Loader is ready...
Erasing area: 01000000 - 01FFFFFF...
Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-392\
Searching for default location of ini...
Checking path: \Products\RM-392\
Searching for JAF saved location of ini...
No ini files found...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__04.91.mcusw
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__04.91.ppm_el
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__04.91.image_el
Backing up PM Field 208 as RPL...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__04.91.mcusw
Booting phone...
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Loader is ready...
MSID: 84177D8382349137A5727C7C92
MSID decoded: 2C40BAE9009218A9A9000000
FAID: 8F4DCC4488FE5447F55B7269
Operation took 0 minutes 10 seconds...
Erasing...
Found 2 interval(s) to erase
Erasing area: 01020000 - 01CFFFFF...
Operation took 1 minutes 14 seconds...
Writing...
Operation took 5 minutes 16 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__04.91.image_el
Booting phone...
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
File is already converted to 128k page...
Loader is ready...
MSID: 84763064E2735ADB14D8C014F7
MSID decoded: D26EBAF1009218A9AA000610
FAID: 4C52696DD64F773438842156
Operation took 0 minutes 9 seconds...
Erasing Content Pack...
Erasing area: 02180000 - 02E7FFFF...
Erasing area: 02E80000 - 02FBFFFF...
Operation took 2 minutes 43 seconds...
Writing...
Operation took 1 minutes 22 seconds...
Restarting MCU...
Operation took 0 minutes 1 seconds...
Extracting Content Pack...
Running: (c) Nokia File Server
CNT Extract OK.
Operation took 0 minutes 4 seconds...
PPM: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__04.91.ppm_el
Unlocking...
ASIC: b
SW version: 04.91
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__04.91.mcusw
Encrypting....Done
Patch status: 00
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Unlocking...
Failed! Aborting!
Failed! Aborting!
pls need some idea....
Old 01-29-2009, 01:36   #9 (permalink)
Member: 62563
Sonork: 100.1589899
Thanks Meter: 26
try to use easy cable..then erase and full flash with MCU+PPM+CNT after that write good pm and unlock...GOLDLUCK
Old 01-29-2009, 01:38   #10 (permalink)
Member: 597471
Thanks Meter: 4
and here also the v5.28
JAF version 1.98.61
Card life counter: 90.72%
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__05.28.mcusw
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__05.28.ppm_ej
Languages in ppm: English,Russian,Ukrainian
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__05.28.image_ej
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\356390020932708_imei_back up_910291.rpl
Done!
Backup imei OK!
MCU: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__05.28.mcusw
Booting phone...
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing...
Operation took 1 minutes 6 seconds...
Writing...
Operation took 5 minutes 24 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__05.28.image_ej
Booting phone...
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Operation took 2 minutes 45 seconds...
Writing...
Operation took 1 minutes 26 seconds...
Restarting MCU...
Operation took 0 minutes 0 seconds...
CNT Extract OK.
Operation took 0 minutes 5 seconds...
PPM: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__05.28.ppm_ej
Booting phone...
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84A92F0584BFC2988E535F1CAA
MSID decoded: 3E4EBAE9009218A9AA000000
FAID: C97C60F998C987091127CDB2
Erasing PPM...
Found 1 interval(s) to erase
Erasing area: 01D00000 - 0217FFFF...
Operation took 0 minutes 34 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 13 minutes 4 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-392, Software version: 05.28
Product Code: 0564368
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Done!
Done!
Unlocking...
ASIC: b
SW version: 05.28
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rm-392\rm392__05.28.mcusw
Encrypting....Done
Patch status: 00
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Failed! Aborting!
Error setting local mode!!!
Done!
The Following User Says Thank You to chrizzz28 For This Useful Post:
Old 01-29-2009, 02:05   #11 (permalink)
Member: 597471
Thanks Meter: 4
pls need some image or schematic of signal solution....
Old 01-29-2009, 05:36   #12 (permalink)
aravimobile's Avatar
Member: 602589
Sonork: 0000001
Thanks Meter: 821
change pa,,it z same as 1110
Old 01-29-2009, 07:42   #13 (permalink)
Member: 597471
Thanks Meter: 4
i try twice change P.A. same problem......very difficult any idea guys,.......
Old 05-30-2009, 12:45   #14 (permalink)
Member: 758550
Thanks Meter: 15
Right, I have chanched PA from 1110 and now its work.
Problem was: NO NETWORK COVERAGE.
Old 06-19-2009, 22:12   #15 (permalink)
Member: 655012
Thanks Meter: 26
give me pm 2680s plz
Nokia 2680s-2 RM-392 how to convert 1800 to 1900? BeaulieuM Nokia Hardware & Hardware Repair 3 10-27-2010 13:44
2680s-2 RM-392 unlock succesfully cllins J.A.F. By Jafsupport.com 6 10-21-2009 13:44
Page generated in 0.53365 seconds with 8 queries
