Old 12-11-2012, 15:18   #1 (permalink)
Member: 1555664
Thanks Meter: 11
Arrow 269o contact srvice plz help me
SW version: V 10.65 09-12-10 RM-635 (c) Nokia
Imei plain: 35486904095335-8
Product code: 059D118
Battery voltage: 4964 mV, current: 72 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00IIIIRR0301022E05, ver: 003.002
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354869040953358
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 12-11-2012, 16:34   #2 (permalink)
Member: 1332469
Sonork: 244747
Thanks Meter: 12
269o contact srvice
269o contact srvice sir hardware problem.
plze check power section
Old 12-11-2012, 16:34   #3 (permalink)
Member: 1332469
Sonork: 244747
Thanks Meter: 12
269o contact srvice
plze check power section.
Check power ic section componase and change powe ic.
Old 12-11-2012, 18:21   #4 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
Change bitty ic'sure shot solution 4 u .
Tested by me.
Old 12-15-2012, 10:02   #5 (permalink)
Member: 1555664
Thanks Meter: 11
SW version: V 10.81 28-02-11 RM-598 (c) Nokia
Imei plain: 35202104975171-2
Battery voltage: 5008 mV, current: 80 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
Camera config: NI00IIIIRR0301035420, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SIMLOCK_DATA corrupted!
Old 12-15-2012, 10:33   #6 (permalink)
Member: 1767975
Thanks Meter: 27
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
post self test i will give you solution
The Following User Says Thank You to mastermobile64 For This Useful Post:
Old 12-15-2012, 11:27   #7 (permalink)
Member: 1555664
Thanks Meter: 11
how to do possible sir plzzzzzz tell me
Old 12-15-2012, 12:49   #8 (permalink)
Registered User
Member: 726546
Sonork: 100.1578784
Thanks Meter: 555
change power ic ( avilma ) urs problem will be solved
Old 12-15-2012, 13:51   #9 (permalink)
trmobile2's Avatar
Member: 1483660
Sonork: 100.1601918
Thanks Meter: 155
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
[IMG]http://3.bp.********.com/-1BIfBWKjLhw/Tg1m0ZJ-aZI/AAAAAAAAAZQ/oYUWUu1EUI8/s1600/2690contactservicesolut.jpg[/IMG]
try to best
Page generated in 0.25239 seconds with 8 queries
