11-08-2010, 20:31 | #1 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1434848 Status: Offline Thanks Meter: 12 | 2700 full pm 0096895340656 0096824832005 any dowt please call me ruppergsm |
01-23-2013, 11:33 | #4 (permalink) |
Major Poster Join Date: Sep 2010 Location: JHAPA-NEPAL
Member: 1386905 Status: Offline Sonork: 100.1620543 Thanks Meter: 8 | card found: registered to: Gazawal Connect phone on selected interface... UFS S/N 1xxxxx boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0D500108564005567C6268A38D46094BCBE6DC8F CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! PrReq : NOR , 00 Init Service mode... Wait... SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0D500108564005567C6268A38D46094BCBE6DC8F CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : 3EA22A1DDA660002E56108DB5072A10F8709443FA8 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 356982045049466 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... Swap data collected to 0581967.pc RPL saved : c:\InfinityBox\BEST\Backup\Cert\356982045049466.rp l Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Operating mode is OK, no need change... Reading PM from field 0 to 400 Field [1] 20 Record(s) Record 0: 12 byte(s) readed - Ok Record 1: 70 byte(s) readed - Ok Record 2: 70 byte(s) readed - Ok Record 3: 70 byte(s) readed - Ok Record 4: 70 byte(s) readed - Ok Record 5: 276 byte(s) readed - Ok Record 6: 276 byte(s) readed - Ok Record 7: 276 byte(s) readed - Ok Record 8: 276 byte(s) readed - Ok Record 9: 384 byte(s) readed - Ok Record 10: 384 byte(s) readed - Ok Record 11: 384 byte(s) readed - Ok Record 12: 384 byte(s) readed - Ok Record 13: 384 byte(s) readed - Ok Record 14: 384 byte(s) readed - Ok Record 15: 384 byte(s) readed - Ok Record 16: 384 byte(s) readed - Ok Record 17: 32 byte(s) readed - Ok Record 19: 16 byte(s) readed - Ok Record 20: 32 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 440 byte(s) readed - Ok Field [4] 9 Record(s) Record 1: 800 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 18: 80 byte(s) readed - Ok Record 19: 4 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [8] 9 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 7: 4 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 24 byte(s) readed - Ok Field [11] 76 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 6 byte(s) readed - Ok Record 6: 2 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 1 byte(s) readed - Ok Record 9: 1 byte(s) readed - Ok Record 10: 1 byte(s) readed - Ok Record 11: 1 byte(s) readed - Ok Record 12: 1 byte(s) readed - Ok Record 13: 1 byte(s) readed - Ok Record 14: 2 byte(s) readed - Ok Record 15: 2 byte(s) readed - Ok Record 16: 2 byte(s) readed - Ok Record 17: 2 byte(s) readed - Ok Record 18: 16 byte(s) readed - Ok Record 19: 32 byte(s) readed - Ok Record 20: 32 byte(s) readed - Ok Record 21: 2 byte(s) readed - Ok Record 22: 2 byte(s) readed - Ok Record 23: 2 byte(s) readed - Ok Record 24: 2 byte(s) readed - Ok Record 25: 2 byte(s) readed - Ok Record 26: 2 byte(s) readed - Ok Record 27: 2 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Record 29: 2 byte(s) readed - Ok Record 30: 2 byte(s) readed - Ok Record 31: 2 byte(s) readed - Ok Record 32: 2 byte(s) readed - Ok Record 33: 2 byte(s) readed - Ok Record 34: 2 byte(s) readed - Ok Record 35: 2 byte(s) readed - Ok Record 36: 2 byte(s) readed - Ok Record 37: 2 byte(s) readed - Ok Record 38: 2 byte(s) readed - Ok Record 39: 2 byte(s) readed - Ok Record 40: 2 byte(s) readed - Ok Record 41: 2 byte(s) readed - Ok Record 42: 2 byte(s) readed - Ok Record 43: 2 byte(s) readed - Ok Record 44: 2 byte(s) readed - Ok Record 45: 2 byte(s) readed - Ok Record 46: 2 byte(s) readed - Ok Record 47: 2 byte(s) readed - Ok Record 48: 2 byte(s) readed - Ok Record 49: 2 byte(s) readed - Ok Record 50: 2 byte(s) readed - Ok Record 51: 2 byte(s) readed - Ok Record 52: 2 byte(s) readed - Ok Record 53: 2 byte(s) readed - Ok Record 54: 2 byte(s) readed - Ok Record 55: 2 byte(s) readed - Ok Record 56: 2 byte(s) readed - Ok Record 57: 2 byte(s) readed - Ok Record 58: 2 byte(s) readed - Ok Record 59: 2 byte(s) readed - Ok Record 60: 2 byte(s) readed - Ok Record 61: 2 byte(s) readed - Ok Record 62: 2 byte(s) readed - Ok Record 63: 2 byte(s) readed - Ok Record 64: 2 byte(s) readed - Ok Record 65: 2 byte(s) readed - Ok Record 66: 4 byte(s) readed - Ok Record 67: 1 byte(s) readed - Ok Record 68: 4 byte(s) readed - Ok Record 69: 4 byte(s) readed - Ok Record 70: 4 byte(s) readed - Ok Record 71: 4 byte(s) readed - Ok Record 72: 16 byte(s) readed - Ok Record 73: 4 byte(s) readed - Ok Record 74: 2 byte(s) readed - Ok Record 75: 13 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 102 byte(s) readed - Ok Field [13] 197 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Record 3: 2 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 2 byte(s) readed - Ok Record 9: 1 byte(s) readed - Ok Record 10: 1 byte(s) readed - Ok Record 11: 48 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Record 13: 1 byte(s) readed - Ok Record 14: 1 byte(s) readed - Ok Record 15: 886 byte(s) readed - Ok Record 16: 2 byte(s) readed - Ok Record 17: 1 byte(s) readed - Ok Record 18: 1 byte(s) readed - Ok Record 19: 8 byte(s) readed - Ok Record 20: 1 byte(s) readed - Ok Record 21: 1 byte(s) readed - Ok Record 22: 1 byte(s) readed - Ok Record 23: 1 byte(s) readed - Ok Record 24: 1 byte(s) readed - Ok Record 25: 2 byte(s) readed - Ok Record 26: 1 byte(s) readed - Ok Record 27: 1 byte(s) readed - Ok Record 28: 1 byte(s) readed - Ok Record 29: 1 byte(s) readed - Ok Record 30: 1 byte(s) readed - Ok Record 31: 1 byte(s) readed - Ok Record 32: 1 byte(s) readed - Ok Record 33: 1 byte(s) readed - Ok Record 34: 1 byte(s) readed - Ok Record 35: 1 byte(s) readed - Ok Record 36: 1 byte(s) readed - Ok Record 37: 4 byte(s) readed - Ok Record 38: 1 byte(s) readed - Ok Record 39: 1 byte(s) readed - Ok Record 40: 1 byte(s) readed - Ok Record 41: 1 byte(s) readed - Ok Record 42: 4 byte(s) readed - Ok Record 43: 4 byte(s) readed - Ok Record 44: 1 byte(s) readed - Ok Record 45: 4 byte(s) readed - Ok Record 46: 4 byte(s) readed - Ok Record 47: 1 byte(s) readed - Ok Record 48: 4 byte(s) readed - Ok Record 49: 1 byte(s) readed - Ok Record 50: 1 byte(s) readed - Ok Record 51: 1 byte(s) readed - Ok Record 52: 2 byte(s) readed - Ok Record 53: 4 byte(s) readed - Ok Record 54: 4 byte(s) readed - Ok Record 55: 1 byte(s) readed - Ok Record 56: 1 byte(s) readed - Ok Record 57: 1 byte(s) readed - Ok Record 58: 2 byte(s) readed - Ok Record 59: 1 byte(s) readed - Ok Record 60: 4 byte(s) readed - Ok Record 61: 4 byte(s) readed - Ok Record 62: 1 byte(s) readed - Ok Record 63: 4 byte(s) readed - Ok Record 64: 4 byte(s) readed - Ok Record 65: 1 byte(s) readed - Ok Record 66: 4 byte(s) readed - Ok Record 67: 4 byte(s) readed - Ok Record 68: 1 byte(s) readed - Ok Record 69: 1 byte(s) readed - Ok Record 70: 1 byte(s) readed - Ok Record 71: 4 byte(s) readed - Ok Record 72: 4 byte(s) readed - Ok Record 73: 1 byte(s) readed - Ok Record 74: 4 byte(s) readed - Ok Record 75: 2 byte(s) readed - Ok Record 76: 2 byte(s) readed - Ok Record 77: 2 byte(s) readed - Ok Record 78: 1 byte(s) readed - Ok Record 79: 1 byte(s) readed - Ok Record 80: 1 byte(s) readed - Ok Record 81: 1 byte(s) readed - Ok Record 82: 1 byte(s) readed - Ok Record 83: 2 byte(s) readed - Ok Record 84: 1 byte(s) readed - Ok Record 85: 4 byte(s) readed - Ok Record 86: 4 byte(s) readed - Ok Record 87: 2 byte(s) readed - Ok Record 88: 1 byte(s) readed - Ok Record 89: 4 byte(s) readed - Ok Record 90: 4 byte(s) readed - Ok Record 91: 2 byte(s) readed - Ok Record 92: 1 byte(s) readed - Ok Record 93: 4 byte(s) readed - Ok Record 94: 4 byte(s) readed - Ok Record 95: 2 byte(s) readed - Ok Record 96: 1 byte(s) readed - Ok Record 97: 4 byte(s) readed - Ok Record 98: 4 byte(s) readed - Ok Record 99: 2 byte(s) readed - Ok Record 100: 4 byte(s) readed - Ok Record 101: 2 byte(s) readed - Ok Record 102: 1 byte(s) readed - Ok Record 103: 4 byte(s) readed - Ok Record 104: 4 byte(s) readed - Ok Record 105: 4 byte(s) readed - Ok Record 106: 4 byte(s) readed - Ok Record 107: 4 byte(s) readed - Ok Record 108: 2 byte(s) readed - Ok Record 109: 4 byte(s) readed - Ok Record 110: 4 byte(s) readed - Ok Record 111: 4 byte(s) readed - Ok Record 112: 2 byte(s) readed - Ok Record 113: 4 byte(s) readed - Ok Record 114: 4 byte(s) readed - Ok Record 115: 1 byte(s) readed - Ok Record 116: 1 byte(s) readed - Ok Record 117: 1 byte(s) readed - Ok Record 118: 4 byte(s) readed - Ok Record 119: 4 byte(s) readed - Ok Record 120: 1 byte(s) readed - Ok Record 121: 1 byte(s) readed - Ok Record 122: 1 byte(s) readed - Ok Record 123: 8 byte(s) readed - Ok Record 124: 1 byte(s) readed - Ok Record 125: 1 byte(s) readed - Ok Record 126: 1 byte(s) readed - Ok Record 127: 1 byte(s) readed - Ok Record 128: 1 byte(s) readed - Ok Record 129: 4 byte(s) readed - Ok Record 130: 4 byte(s) readed - Ok Record 131: 1 byte(s) readed - Ok Record 132: 1 byte(s) readed - Ok Record 133: 2 byte(s) readed - Ok Record 134: 1 byte(s) readed - Ok Record 135: 2 byte(s) readed - Ok Record 136: 1 byte(s) readed - Ok Record 137: 1 byte(s) readed - Ok Record 138: 4 byte(s) readed - Ok Record 139: 4 byte(s) readed - Ok Record 140: 1 byte(s) readed - Ok Record 141: 1 byte(s) readed - Ok Record 142: 1 byte(s) readed - Ok Record 143: 1 byte(s) readed - Ok Record 144: 4 byte(s) readed - Ok Record 145: 8 byte(s) readed - Ok Record 146: 4 byte(s) readed - Ok Record 147: 4 byte(s) readed - Ok Record 148: 1 byte(s) readed - Ok Record 149: 1 byte(s) readed - Ok Record 150: 1 byte(s) readed - Ok Record 151: 1 byte(s) readed - Ok Record 152: 1 byte(s) readed - Ok Record 153: 1 byte(s) readed - Ok Record 154: 1 byte(s) readed - Ok Record 155: 1 byte(s) readed - Ok Record 156: 1 byte(s) readed - Ok Record 157: 1 byte(s) readed - Ok Record 158: 1 byte(s) readed - Ok Record 159: 2 byte(s) readed - Ok Record 160: 2 byte(s) readed - Ok Record 161: 1 byte(s) readed - Ok Record 162: 1 byte(s) readed - Ok Record 163: 1 byte(s) readed - Ok Record 164: 1 byte(s) readed - Ok Record 165: 1 byte(s) readed - Ok Record 166: 1 byte(s) readed - Ok Record 167: 8 byte(s) readed - Ok Record 168: 4 byte(s) readed - Ok Record 169: 1 byte(s) readed - Ok Record 170: 1 byte(s) readed - Ok Record 171: 1 byte(s) readed - Ok Record 172: 1 byte(s) readed - Ok Record 173: 1 byte(s) readed - Ok Record 174: 1 byte(s) readed - Ok Record 175: 1 byte(s) readed - Ok Record 176: 1 byte(s) readed - Ok Record 177: 4 byte(s) readed - Ok Record 178: 2 byte(s) readed - Ok Record 179: 1 byte(s) readed - Ok Record 180: 1 byte(s) readed - Ok Record 181: 1 byte(s) readed - Ok Record 182: 1 byte(s) readed - Ok Record 183: 1 byte(s) readed - Ok Record 184: 1 byte(s) readed - Ok Record 185: 1 byte(s) readed - Ok Record 186: 1 byte(s) readed - Ok Record 187: 1 byte(s) readed - Ok Record 188: 1 byte(s) readed - Ok Record 189: 1 byte(s) readed - Ok Record 190: 4 byte(s) readed - Ok Record 191: 2 byte(s) readed - Ok Record 192: 1 byte(s) readed - Ok Record 193: 4 byte(s) readed - Ok Record 194: 1 byte(s) readed - Ok Record 195: 1 byte(s) readed - Ok Record 196: 10 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 14 byte(s) readed - Ok Field [42] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [54] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [66] 69 Record(s) Record 0: 481 byte(s) readed - Ok Record 1: 240 byte(s) readed - Ok Record 2: 240 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 240 byte(s) readed - Ok Record 6: 4 byte(s) readed - Ok Record 7: 4 byte(s) readed - Ok Record 8: 4 byte(s) readed - Ok Record 9: 4 byte(s) readed - Ok Record 10: 240 byte(s) readed - Ok Record 11: 240 byte(s) readed - Ok Record 12: 1 byte(s) readed - Ok Record 16: 4 byte(s) readed - Ok Record 18: 4 byte(s) readed - Ok Record 20: 4 byte(s) readed - Ok Record 22: 4 byte(s) readed - Ok Record 24: 4 byte(s) readed - Ok Record 26: 4 byte(s) readed - Ok Record 28: 4 byte(s) readed - Ok Record 30: 4 byte(s) readed - Ok Record 32: 4 byte(s) readed - Ok Record 54: 8 byte(s) readed - Ok Record 55: 8 byte(s) readed - Ok Record 56: 8 byte(s) readed - Ok Record 57: 8 byte(s) readed - Ok Record 58: 8 byte(s) readed - Ok Record 59: 8 byte(s) readed - Ok Record 60: 8 byte(s) readed - Ok Record 61: 8 byte(s) readed - Ok Record 62: 8 byte(s) readed - Ok Record 63: 8 byte(s) readed - Ok Record 64: 8 byte(s) readed - Ok Record 65: 8 byte(s) readed - Ok Record 66: 8 byte(s) readed - Ok Record 67: 8 byte(s) readed - Ok Record 68: 8 byte(s) readed - Ok Record 69: 8 byte(s) readed - Ok Record 71: 8 byte(s) readed - Ok Record 72: 8 byte(s) readed - Ok Record 73: 24016 byte(s) readed - Ok Record 74: 6144 byte(s) readed - Ok Record 75: 300 byte(s) readed - Ok Record 76: 60 byte(s) readed - Ok Record 79: 60000 byte(s) readed - Ok Record 81: 3 byte(s) readed - Ok Record 82: 3 byte(s) readed - Ok Record 83: 3 byte(s) readed - Ok Record 85: 3 byte(s) readed - Ok Record 86: 3 byte(s) readed - Ok Record 87: 3 byte(s) readed - Ok Record 89: 4 byte(s) readed - Ok Record 94: 8 byte(s) readed - Ok Record 97: 4 byte(s) readed - Ok Record 98: 4 byte(s) readed - Ok Record 99: 4 byte(s) readed - Ok Record 100: 4 byte(s) readed - Ok Record 101: 4 byte(s) readed - Ok Record 102: 6 byte(s) readed - Ok Record 104: 4 byte(s) readed - Ok Record 111: 120 byte(s) readed - Ok Record 112: 2 byte(s) readed - Ok Record 114: 30 byte(s) readed - Ok Record 115: 1 byte(s) readed - Ok Record 116: 20 byte(s) readed - Ok Record 118: 8 byte(s) readed - Ok Record 119: 8 byte(s) readed - Ok Record 120: 8 byte(s) readed - Ok Record 122: 7 byte(s) readed - Ok Field [88] 1 Record(s) Record 0: 36 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 6 Record(s) Record 0: 21 byte(s) readed - Ok Record 1: 89 byte(s) readed - Ok Record 2: 69 byte(s) readed - Ok Record 3: 70 byte(s) readed - Ok Record 25: 132 byte(s) readed - Ok Record 26: 12 byte(s) readed - Ok Field [116] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [117] 9 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 13: 3 byte(s) readed - Ok Record 14: 3 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [163] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [218] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [232] 3 Record(s) Record 0: 20 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Field [238] 1 Record(s) Record 1: 1 byte(s) readed - Ok Field [250] 4 Record(s) Record 1: 2248 byte(s) readed - Ok Record 2: 128 byte(s) readed - Ok Record 3: 782 byte(s) readed - Ok Record 4: 40 byte(s) readed - Ok Field [301] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [308] 9 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 9 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 5: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 8: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Record 22: 12 byte(s) readed - Ok Field [320] 39 Record(s) Record 0: 148 byte(s) readed - Ok Record 1: 148 byte(s) readed - Ok Record 2: 148 byte(s) readed - Ok Record 3: 148 byte(s) readed - Ok Record 4: 148 byte(s) readed - Ok Record 5: 148 byte(s) readed - Ok Record 6: 148 byte(s) readed - Ok Record 7: 148 byte(s) readed - Ok Record 8: 148 byte(s) readed - Ok Record 9: 148 byte(s) readed - Ok Record 10: 148 byte(s) readed - Ok Record 11: 148 byte(s) readed - Ok Record 12: 148 byte(s) readed - Ok Record 13: 148 byte(s) readed - Ok Record 14: 148 byte(s) readed - Ok Record 15: 148 byte(s) readed - Ok Record 16: 148 byte(s) readed - Ok Record 17: 148 byte(s) readed - Ok Record 18: 148 byte(s) readed - Ok Record 19: 148 byte(s) readed - Ok Record 20: 148 byte(s) readed - Ok Record 21: 148 byte(s) readed - Ok Record 22: 148 byte(s) readed - Ok Record 23: 148 byte(s) readed - Ok Record 24: 148 byte(s) readed - Ok Record 25: 148 byte(s) readed - Ok Record 26: 148 byte(s) readed - Ok Record 27: 148 byte(s) readed - Ok Record 28: 148 byte(s) readed - Ok Record 29: 148 byte(s) readed - Ok Record 30: 148 byte(s) readed - Ok Record 31: 148 byte(s) readed - Ok Record 32: 148 byte(s) readed - Ok Record 33: 148 byte(s) readed - Ok Record 34: 148 byte(s) readed - Ok Record 35: 148 byte(s) readed - Ok Record 36: 148 byte(s) readed - Ok Record 37: 148 byte(s) readed - Ok Record 38: 148 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [339] 2 Record(s) Record 0: 511 byte(s) readed - Ok Record 1: 511 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4394 byte(s) readed - Ok Field [345] 1 Record(s) Record 0: 12 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 33 byte(s) readed - Ok Field [355] 1 Record(s) Record 1: 2028 byte(s) readed - Ok Field [356] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [362] 2 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 144 byte(s) readed - Ok Field [364] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [365] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\RM-561 Nokia 2700 classic_356982045049466_0_400.pm Done! Elapsed: 00:01:55 Operating mode is OK, no need change... Field 1 Record 0 write - Error Record 1 write - Error Record 2 write - Error Record 3 write - Error Record 4 write - Error Record 5 write - Error Record 6 write - Error Record 7 write - Error Record 8 write - Error Record 9 write - Error Record 10 write - Error Record 11 write - Error Record 12 write - Error Record 13 write - Error Record 14 write - Error Record 15 write - Error Record 16 write - Error Record 17 write - Error Record 19 write - Error Record 20 write - Error Field 2 Record 0 write - Ok Field 4 Record 1 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 9 write - Ok Record 18 write - Ok Record 19 write - Ok Record 28 write - Ok Field 8 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Field 11 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 70 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Field 12 Record 0 write - Ok Field 13 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 70 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Record 76 write - Ok Record 77 write - Ok Record 78 write - Ok Record 79 write - Ok Record 80 write - Ok Record 81 write - Ok Record 82 write - Ok Record 83 write - Ok Record 84 write - Ok Record 85 write - Ok Record 86 write - Ok Record 87 write - Ok Record 88 write - Ok Record 89 write - Ok Record 90 write - Ok Record 91 write - Ok Record 92 write - Ok Record 93 write - Ok Record 94 write - Ok Record 95 write - Ok Record 96 write - Ok Record 97 write - Ok Record 98 write - Ok Record 99 write - Ok Record 100 write - Ok Record 101 write - Ok Record 102 write - Ok Record 103 write - Ok Record 104 write - Ok Record 105 write - Ok Record 106 write - Ok Record 107 write - Ok Record 108 write - Ok Record 109 write - Ok Record 110 write - Ok Record 111 write - Ok Record 112 write - Ok Record 113 write - Ok Record 114 write - Ok Record 115 write - Ok Record 116 write - Ok Record 117 write - Ok Record 118 write - Ok Record 119 write - Ok Record 120 write - Ok Record 121 write - Ok Record 122 write - Ok Record 123 write - Ok Record 124 write - Ok Record 125 write - Ok Record 126 write - Ok Record 127 write - Ok Record 128 write - Ok Record 129 write - Ok Record 130 write - Ok Record 131 write - Ok Record 132 write - Ok Record 133 write - Ok Record 134 write - Ok Record 135 write - Ok Record 136 write - Ok Record 137 write - Ok Record 138 write - Ok Record 139 write - Ok Record 140 write - Ok Record 141 write - Ok Record 142 write - Ok Record 143 write - Ok Record 144 write - Ok Record 145 write - Ok Record 146 write - Ok Record 147 write - Ok Record 148 write - Ok Record 149 write - Ok Record 150 write - Ok Record 151 write - Ok Record 152 write - Ok Record 153 write - Ok Record 154 write - Ok Record 155 write - Ok Record 156 write - Ok Record 157 write - Ok Record 158 write - Ok Record 159 write - Ok Record 160 write - Ok Record 161 write - Ok Record 162 write - Ok Record 163 write - Ok Record 164 write - Ok Record 165 write - Ok Record 166 write - Ok Record 167 write - Ok Record 168 write - Ok Record 169 write - Ok Record 170 write - Ok Record 171 write - Ok Record 172 write - Ok Record 173 write - Ok Record 174 write - Ok Record 175 write - Ok Record 176 write - Ok Record 177 write - Ok Record 178 write - Ok Record 179 write - Ok Record 180 write - Ok Record 181 write - Ok Record 182 write - Ok Record 183 write - Ok Record 184 write - Ok Record 185 write - Ok Record 186 write - Ok Record 187 write - Ok Record 188 write - Ok Record 189 write - Ok Record 190 write - Ok Record 191 write - Ok Record 192 write - Ok Record 193 write - Ok Record 194 write - Ok Record 195 write - Ok Record 196 write - Ok Field 31 Record 4 write - Ok Field 42 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Field 44 Record 0 write - Ok Field 50 Record 0 write - Ok Field 54 Record 0 write - Ok Field 66 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 22 write - Ok Record 24 write - Ok Record 26 write - Ok Record 28 write - Ok Record 30 write - Ok Record 32 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Record 76 write - Ok Record 79 write - Ok Record 81 write - Ok Record 82 write - Ok Record 83 write - Ok Record 85 write - Ok Record 86 write - Ok Record 87 write - Ok Record 89 write - Ok Record 94 write - Ok Record 97 write - Ok Record 98 write - Ok Record 99 write - Ok Record 100 write - Ok Record 101 write - Ok Record 102 write - Ok Record 104 write - Ok Record 111 write - Ok Record 112 write - Ok Record 114 write - Ok Record 115 write - Ok Record 116 write - Ok Record 118 write - Ok Record 119 write - Ok Record 120 write - Ok Record 122 write - Ok Field 88 Record 0 write - Ok Field 96 Record 0 write - Ok Record 1 write - Ok Field 107 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 25 write - Ok Record 26 write - Ok Field 116 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Field 117 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 5 write - Ok Record 6 write - Ok Record 13 write - Ok Record 14 write - Ok Record 16 write - Ok Field 120 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Field 163 Record 0 write - Ok Field 193 Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 9 write - Ok Field 218 Record 0 write - Ok Field 232 Record 0 write - Ok Record 2 write - Ok Record 3 write - Ok Field 238 Record 1 write - Ok Field 250 Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Field 301 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Field 308 Record 0 write - Error Record 1 write - Error Record 3 write - Error Record 4 write - Error Record 5 write - Error Record 6 write - Error Record 7 write - Error Record 8 write - Error Record 9 write - Error Field 309 Record 0 write - Error Record 1 write - Error Record 2 write - Error Record 4 write - Error Record 5 write - Error Record 7 write - Error Record 8 write - Error Record 17 write - Error Record 22 write - Error Field 320 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Field 322 Record 0 write - Ok Field 334 Record 0 write - Ok Field 339 Record 0 write - Ok Record 1 write - Ok Field 341 Record 0 write - Ok Record 3 write - Ok Record 4 write - Ok Field 345 Record 0 write - Ok Field 354 Record 0 write - Ok Field 355 Record 1 write - Ok Field 356 Record 0 write - Ok Field 362 Record 0 write - Ok Record 1 write - Ok Field 364 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Field 365 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Done! Elapsed: 00:01:11 IN NOKIA2700c....... Plz urrrrrrrrrrrrrrrrrrrgent help Any bobyyyy |
Full Flash 5130 V05.61 | nokia_flash | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-03-2011 15:38 |
Wanted 6130 4.02 full backup Pls Read | Charly | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-06-2001 05:12 |
6150 Full Flash , Help | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-03-2001 13:34 |
Full flash for 6110 v5.24 needed | tcfx44 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-30-2001 14:04 |
NOKEY BOX FOR SALE - FULL | Zorz | Main Sales Section | 0 | 12-05-2000 10:56 |
