01-12-2011, 13:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | 2700c insert bettry not power on please help i am try hwk box flash lettest v 9.98 ui setting on info ok here normall mode ok phone working well but insert bettary not power on i am check bettary socket way way is ok change bettary 5 pc onther phone working or i am normall heat on pcb but same here please help i am waiting here |
01-13-2011, 06:22 | #5 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1292649 Status: Offline Sonork: [email protected] Thanks Meter: 41 | check charging if charging show .change keypad ic or contact with me i send u on/off sulution [email protected] |
01-13-2011, 06:52 | #6 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
power on/off way going via keypad ic | |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
01-13-2011, 06:59 | #8 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Only keypad problem so change or replace keypad ic already posted on the forum. VISIT HERE br, ABDUL HAKEEM |
The Following User Says Thank You to >>PakFones<< For This Useful Post: |
01-13-2011, 08:37 | #9 (permalink) | ||
Member: 823633 Status: Offline Thanks Meter: 1,705 | Quote:
phone insert charger not show here charging | ||
01-13-2011, 10:12 | #10 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Cel_Phon - M.B.Din
Member: 328187 Status: Offline Thanks Meter: 1,687 | connect ur set with box select normal mode ....after power up ur set press on off key if not work then u must replace keypad ic......but if power key works fine then check ground pin of battery connector ......attach that pin direct to ground and check.... |
01-13-2011, 11:01 | #11 (permalink) | |
ground pin is okey here noraml mode phone power on after power key presh power off here bettry socket way ic okey here i think power ic prob here | |
01-13-2011, 11:17 | #13 (permalink) | |
Freak Poster Join Date: Feb 2010 Location: Narayanganj, Bangladesh. Age: 36
Member: 1226253 Status: Offline Sonork: 1602755 Thanks Meter: 69 | Quote:
thanxxxxxxxxxxxx | |
01-14-2011, 07:12 | #15 (permalink) |
Member: 1292649 Status: Offline Sonork: [email protected] Thanks Meter: 41 | ist check power on/off tracks..... i think track is miss ....... change keypad ic ok work tested by me very time.. [email protected] |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
