11-22-2007, 04:27 | #1 (permalink) |
Junior Member Join Date: May 2007
Member: 513721 Status: Offline Thanks Meter: 52 | nokia 1110 1600 contact service new solution 2- Fash your phone using it original firmware 3- write 1100 pm 4- Flash it again with its original firmware 5- Write its original PM values 6- 110% your contact service is gone 7- Unlock if needed 8- End |
The Following User Says Thank You to mr_chauhan18381 For This Useful Post: |
11-27-2007, 12:03 | #4 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 582515 Status: Offline Thanks Meter: 70 | when i trying to flash 1110 with jaf.. but the jaf window shows Getting MCU ID MCU ID: 0x2201 FLASH ID0: 93400A41 -> Unknown flash chip Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 8D 40 0A 41 50 A8 C0 E2 5D 99 8B E4 43 EE 45 CC Checking RAM for ALGO... Can't find flash loader for this phone...Aborting! so what can i do further... whats the perfect solution.. |
01-01-2008, 12:06 | #5 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Deep Blue G.S.M.
Member: 225229 Status: Offline Thanks Meter: 90 | Quote:
Reball or change your Fash Chip. | |
The Following User Says Thank You to nishaon For This Useful Post: |
01-01-2008, 12:48 | #6 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | Quote:
nope! bro its not a healthy solution if set on contact service due to software then just do unlock option it will be work perfactly well i tryyyyyy ur solution at 3 set at the time but failed to get result wbr ahmad | |
01-02-2008, 23:28 | #12 (permalink) |
No Life Poster Join Date: Mar 2007 Location: TuNiSiA
Member: 462224 Status: Offline Sonork: 100.1586374 Thanks Meter: 103 | if your problem is software, then no need to do all this, just full erase, reflash your phone to the latest version, write pm and unlock. if you still have CS, it's 1000% hardware. |
01-03-2008, 07:42 | #13 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | contact service come for two causes 1. softwere 2. hardwere if softwere then not need to do a lot thing just erase and full flash with latest version file, if not ok then this is hardwere problem |
03-23-2008, 09:19 | #15 (permalink) |
Insane Poster Join Date: Jul 2006 Location: Badami Age: 48
Member: 307420 Status: Offline Thanks Meter: 17 | hello sir water damaged cell 111oi i have cleaned pcb with chemical after that comes contact service , now erased, flash with new version but problem now still plse help me |
1110 1600 contact service new solution 10000000% ok | mr_chauhan18381 | Nokia Hardware & Hardware Repair | 55 | 09-28-2015 11:12 |
Nokia 1110 rh70 contact service solution 100%(INGS*****) | alammov | Nokia Hardware & Hardware Repair | 10 | 02-15-2011 18:06 |
1110/12,2310, 6030 contact service new solution | Parminder Singh | Nokia Hardware & Hardware Repair | 25 | 11-12-2009 13:29 |
1110,1600 contact service | shaikapsar | Nokia Hardware & Hardware Repair | 3 | 11-22-2008 16:31 |
nokia 1110 1600 contact service | ayaz ali | Nokia Hardware & Hardware Repair | 8 | 04-05-2007 13:40 |
