09-21-2011, 18:12 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::2700c nokia white light than off::.. already reball double ic MXKEY Serial: [FT SCR2000 0] - C0805720 Using device: AdvanceBox Turbo Flasher Driver: FTDIBUS, ver: 2.6.0.0 , NTMP ver: 2.6.2.0 Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011) Processing MCU file: rm561__09.98.mcusw [BB5,BB5 ALGORITHM] size: 19.41 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0E500101EF348E567011BB83EA58C5F35FA568C1 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00040000-000BFFFF] CMT NOR area [000C0000-0013FFFF] CMT NOR area [00140000-0137FFFF] CMT NOR area [01380000-0151FFFF] erased in 1 min 19.859 s TransmissionMode: DDR&TX2 Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 3EA22A1DDA6600FE6E73CED7D8C6268C8EB85723 (RAP Certificate 202 v.1) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 14 min 49.922 s Total time for flashing process(boot+erase+write) was 16 min 25.359 s Phone not responding ! |
The Following User Says Thank You to HUM For This Useful Post: |
09-21-2011, 18:20 | #2 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1635037 Status: Offline Sonork: 1590479 Thanks Meter: 41 | NOKIA 5130c-2690c-2700c Nokia Logo Trun Off Check Solution Step By Step A1) flash lhe phone higher version via usb or Fbus 2) usb flashing time computer show usb error? must check usb connector usb controll driver(remove usb esd) usb flashing and fbus flash 100% done?but phone same nokia logo then trun off? B1) open handset then check display connector or change display(display also make this problem) 2) remove camera and power on phone with battery,phone still same problem(nokialogo then trun off 3) check vcore,vio,vdram vrfc volt this 4 volt controlled by combo ic vdram,vrfc,vio volt controlled by AVILMA Vcore controlled by BETTY this 4 volt is prefect???then one thing is conformed avilma betty working fine 4) reflow or change keypad ic 5) Remove MMC ic 6) BT ic also make this problem(6120 75% nokia trun off bt ic) 7) finaly reflow or change combo ic Respected viewers if you have any openion please post here its healpfull to all. ONE SULATION MORE.... only nokia logo hang(5130,2690,2700c ect with light or withouT light) solution tested first of all flash with latest version if no then remove camera if no then finally replace bt ic shown in picture. http://forum.gsmhosting.com/vbb/6949480-post7.html OR Just rehot this avilma. Hpre your problem will be solve. |
09-22-2011, 02:34 | #6 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | please tell me the procedure how u solve this type of problem? i got this phone in this problem when power on set show nokia than white screen and off in this case how i backup pm and rpl bcoz phone not enter into local mode and where u get the other flash ic need ur assistence |
