Old 03-15-2010, 09:12   #1 (permalink)
Member: 1261122
Thanks Meter: 21
2760
need help.2760 restart when opening the camera application.i need all your help
Old 03-15-2010, 09:19   #2 (permalink)
shahzadthe1's Avatar
Member: 541117
Sonork: .::100.1586906::.
Thanks Meter: 173
http://forum.gsmhosting.com/vbb/4497794-post33.html
BR.,
Old 03-15-2010, 11:56   #3 (permalink)
Member: 1261122
Thanks Meter: 21
still not working sir,i done flashing with universal box.do you have other solution?
Old 03-15-2010, 12:52   #4 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.change flex cable...
result post here.
Old 03-18-2010, 03:59   #5 (permalink)
Member: 1261122
Thanks Meter: 21
n73
friend i have n73 a little bit ground.hard to locate the ground.urgently needed.
Old 02-15-2011, 16:27   #6 (permalink)
Crazy Poster
Member: 80729
Thanks Meter: 5
i have the same problem and i tried without top side : go to camera option and before you turn on camera take out the conector on the lcd side an hit the button to turn on camrea; if the light's on the pcb(keybord ) turn off and then on again that means the phone has restarted itself and the problem is from pcb... NOW my question is if someone has a solution for the camera when the problem is from pcb and it's not a software problem (already tried to write software and dinamic camera configuration and no result)....
The Following User Says Thank You to vasihdtel For This Useful Post:
2760 b to 2760 WAGES Nokia Hardware & Hardware Repair 0 07-18-2008 20:21
New Product: New Nokia 2760 JAF cable Tele-way Main Sales Section 0 08-30-2007 07:22
Page generated in 0.18194 seconds with 10 queries
