Old 10-07-2005, 22:44   #1 (permalink)
Member: 47029
30sec problem In Nokia 2300 & 1100h
hi every body: I have two sets Nokia 2300 and nokia 1100 it's IMEI ?????????? i'M Solved It My by send ask file AND RECEIVED rpl ( OUTO SERVER) Phones is work but It shut down afer 30 sec pls any one know some thing about that can help me
Old 10-07-2005, 22:49   #2 (permalink)
Member: 67130
try to reflash it mate .........................
Old 10-08-2005, 01:14   #3 (permalink)
Member: 44950
Thanks Meter: 10
flash the phone then rewrite the rpl again.......
Old 10-08-2005, 01:41   #4 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
it's not software problem , you need change new UEM
Old 10-08-2005, 13:31   #5 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
Help
can anyone help me 1100 and 2300 main pm files, if i select mine, it will tell me file not found, but the file is there.
Old 10-09-2005, 04:31   #6 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
try this ..............
1.http:///vbb/showthread.php?t=231141
bestman
Old 10-09-2005, 05:11   #7 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
bestman
------------------Wrong Link----------------------------
Old 10-09-2005, 07:40   #8 (permalink)
Member: 13545
Thanks Meter: 2
nokia 1100 and 2300 phones when u got imei ??????????????? in most cases u have a bad UEM,
to be sure if it is a bad UEM or not , read UEM data using Griffin, if the imei is the same as the imei labeled on back of the phone then this is rpl problem!
if the imei is differs from the imei labeled then UEM bad!!! (most cases) then u need to change UEM! u must have experince with changing glued uem's
"assume that the frame "chasis" for the phone was the original"
MrHazeem
Old 10-09-2005, 14:36   #9 (permalink)
Member: 160349
replace ur uem(4376001/4370825)..2300&1100 normaly using uem(4376401)tis uem had some problem..
Old 10-09-2005, 21:43   #10 (permalink)
Member: 47029
yes It's UEM problem COS I find anther 2300 phone with IMEI ?????????? befor I'm do anything INIt I'm let It 30sec It shut down this means not soft ware not RPL
Old 10-10-2005, 07:28   #11 (permalink)
Member: 56049
Thanks Meter: 4
if you are using safa software, as soon as you istall the main suite you already have the pm of 11oo. to get this go to the location you install the software go to nokia, open pm file, select 1100 main use that one and you have a good pm file
how 2 install hindi language in nokia 2300 gsm_cdma_ufs Nokia Hardware & Hardware Repair 7 04-30-2009 01:14
" insert sim card " in Nokia 1100 & 2300 Mobile Lab Griffin 45 04-28-2009 09:09
Network Problem in Nokia 2300 benwhitney Nokia Digital Core Technology 4 ( DCT-4 ) 9 04-01-2008 06:44
Problem flshing Nokia 2300 polsius Nokia Digital Core Technology 4 ( DCT-4 ) 9 12-03-2004 17:39
Problem Downloading Ringtone For Nokia 2300 & 1100 Pardoon Nokia Multimedia 9 08-29-2004 12:37
Page generated in 0.36473 seconds with 9 queries
