05-15-2006, 14:09 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 268930 Status: Offline Thanks Meter: 23 | 3100 blinking problem with out sim it is ok but with sim it is blinking I flash it mcu+ppm+pmm+cnt and with out cnt write pm UI option after this erase flash and again flash but problem is still the sam pleas help how can i sold this problem |
05-15-2006, 14:19 | #2 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
05-15-2006, 14:26 | #3 (permalink) | |
Registered User Join Date: Oct 2005
Member: 195513 Status: Offline Thanks Meter: 67 | Quote:
05-16-2006, 08:19 | #5 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: India Age: 43
Member: 169384 Status: Offline Thanks Meter: 110 | Quote:
06-27-2006, 02:32 | #7 (permalink) |
Junior Member Join Date: Jun 2006
Member: 300907 Status: Offline Thanks Meter: 2 | 3100 Lcd Blinking. Hi, I am trying to flash a dead nokia 2600 with ufs Box. Select 3100 --> Erase --> Start Address 01000000 (Default) --> Change the End Address 01FFFFFF to 013FFFFF. Now erase the flash area. Then write MCU and PPM files. Now Phone OK. (GSM 900 Mhz Signal Error). Write 1100 PM File 34% only (Do not write full pm file). Remove the tick (Un Select) in Autodetect Product. Select 1100 --> Wr PM --> 1100 pm file --> Stop in 34% . Now phone work with 100% Good Signal. Use same Method for 2600 & 3120. Thanks. |
06-27-2006, 02:34 | #8 (permalink) |
Member: 300907 Status: Offline Thanks Meter: 2 | 3100 lcd Blinking. Hi, I am trying to flash a dead nokia 3100 with ufs Box. Select 3100 --> Erase --> Start Address 01000000 (Default) --> Change the End Address 01FFFFFF to 013FFFFF. Now erase the flash area. Then write MCU and PPM files. Now Phone OK. (GSM 900 Mhz Signal Error). Write 1100 PM File 34% only (Do not write full pm file). Remove the tick (Un Select) in Autodetect Product. Select 1100 --> Wr PM --> 1100 pm file --> Stop in 34% . Now phone work with 100% Good Signal. Use same Method for 2600 & 3120. Thanks. |
3100 blink | gangadhar121212 | Nokia Hardware & Hardware Repair | 4 | 09-21-2009 16:34 |
3100 Blink And Switch Off | jamohaki | Nokia Hardware & Hardware Repair | 2 | 09-01-2007 08:28 |
!!! Nokia 3100 display problems !!! | OncleOh | Nokia Hardware & Hardware Repair | 4 | 04-02-2004 09:49 |
Nokia 3100 Unlock Problems | garry23 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 02-10-2004 16:22 |
3100 charging problem... | hrco | Nokia Hardware & Hardware Repair | 1 | 12-06-2003 06:51 |
