Old 03-25-2007, 15:51   #1 (permalink)
Member: 296067
Thanks Meter: 50
3100 buzzer problem
3100 has buzzer problem and led problem ,tq.
Old 03-25-2007, 16:57   #2 (permalink)
neokia's Avatar
Member: 366974
Thanks Meter: 31
check this out....
The Following User Says Thank You to neokia For This Useful Post:
Old 03-25-2007, 17:11   #3 (permalink)
MATRIX.REAL's Avatar
Member: 202333
Thanks Meter: 178
hello
try to use ARCHIT RAJ SOLUTION posted by neokia
i think that worked ...
Old 03-25-2007, 17:40   #4 (permalink)
kailash_gm's Avatar
Member: 101117
Thanks Meter: 466
[QUOTE=gpong;2338838]3100 has buzzer problem and led problem ,tq.[/QUOif ur
if ur ringer work some time u must just heat the upp if nothing rings so use the above soln...
ur disply connector is dry just ressolder it it will be ok
best of luck
Old 03-25-2007, 17:53   #5 (permalink)
Member: 320354
Thanks Meter: 48
thx for sharing ~
keep going ~brother
Old 03-26-2007, 02:06   #6 (permalink)
Member: 296067
Thanks Meter: 50
t q,alll goood guy.i will trie.
Old 03-26-2007, 04:51   #7 (permalink)
Allunlockingsource's Avatar
Member: 333439
Sonork: 100.1589101
Thanks Meter: 623
3100
plz reheat ic or change ic maybe your problem is solve ok
The Following 2 Users Say Thank You to Allunlockingsource For This Useful Post:
Old 03-26-2007, 04:57   #8 (permalink)
Member: 470867
Thanks Meter: 32
hit the cpu ic with fux 100% work
Old 03-26-2007, 05:40   #9 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,912
bro chack ringer ways this is ok so chage ringer ic
Old 03-27-2007, 08:49   #10 (permalink)
Member: 104473
reboil cpu is 80% good fix
Old 03-27-2007, 09:30   #11 (permalink)
jaggi's Avatar
Member: 258480
Thanks Meter: 14
change the ringer ic
Old 04-22-2007, 19:30   #12 (permalink)
Member: 333439
Sonork: 100.1589101
Thanks Meter: 623
Brotehr chagne sound ic you problem slove sound ok
The Following User Says Thank You to Allunlockingsource For This Useful Post:
Old 04-22-2007, 19:41   #13 (permalink)
Member: 476705
chek one cpu&rasitant trak
Old 03-08-2008, 22:42   #14 (permalink)
MEDIA_NADIM's Avatar
Member: 268712
Thanks Meter: 479
works 100000% tested
brother try this sol...
its works 10000000%
The Following User Says Thank You to MEDIA_NADIM For This Useful Post:
Old 06-24-2008, 14:58   #15 (permalink)
Member: 712452
ple tel me brother 3100 no disply but light on
good solution of 3100 buzzer problem brahim Nokia Hardware & Hardware Repair 7 02-13-2009 16:25
3100 buzzer c0c0 Nokia Hardware & Hardware Repair 17 06-10-2008 09:23
buzzer problem of 3100 habibkhalil Nokia Hardware & Hardware Repair 1 12-28-2005 21:03
Sony J70 buzzer problem Porter Sony Ericsson Hardware Repair 9 03-16-2005 11:36
3210 Buzzer Problem! aspog Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-05-2001 17:06
Page generated in 0.27490 seconds with 10 queries
