05-10-2007, 10:27 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 477410 Status: Offline Thanks Meter: 2 | 3100 dead problem thanks |
The Following User Says Thank You to M.YASIR For This Useful Post: |
05-16-2007, 18:57 | #10 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 374225 Status: Offline Thanks Meter: 41 | sir ur set is ok ...u have cable prob or install ur ufs again ...to confirm more flash any other 3100 so that u may come to final solution tht what is corrupt ...ur set or ufs or cable ? |
07-20-2008, 05:05 | #11 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 199996 Status: Offline Thanks Meter: 41 | 3100 dead problems: when i try to flash by jaf it shows as follows: Failed to backup imei... MCU: D:\Nokia\Phoenix\Products\RH-19\rh19__06.110 Booting phone... MCU ID: 0x2142 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 277E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E270100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7518; Loader chk: 1d Error Loading loader! Where is the problems |
07-20-2008, 08:16 | #14 (permalink) |
Member: 199996 Status: Offline Thanks Meter: 41 | I have another 3100 . its problem is "network coverage" I have heat all flasher, UMEI, CPU, Changed PA, Antina, Cuplar but it has no change, 5 keypad is not working. have any solution? |
07-21-2008, 18:41 | #15 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 286908 Status: Offline Thanks Meter: 81 | HI friend if not wok key 5 just heat well upp it will be ok 3100 main problem netwok i have solve this ways wash pcb with tinner 30 minuts dry well with hot air chek network if not done chenge small 4 chips arund the rf ic i canot atach picture here regards |
3100 dead ufs2 | TechPhone | Nokia Hardware & Hardware Repair | 5 | 08-25-2004 11:18 |
3100 dead ufs2 | TechPhone | UFS2 + UFS3-Tornadoflasher | 2 | 08-24-2004 06:17 |
3100 dead but charging | Lukas123 | Nokia Hardware & Hardware Repair | 6 | 08-17-2004 21:38 |
how i can flash Nokia 3100.....dead after flashing | bart3 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 07-29-2004 14:22 |
