03-01-2007, 13:03 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 396639 Status: Offline Thanks Meter: 16 | 3100 flash ok,not switch on |
03-01-2007, 18:35 | #5 (permalink) |
No Life Poster Join Date: May 2006 Location: U wont beleive Age: 43
Member: 275631 Status: Offline Thanks Meter: 408 | does ur fon complete UI setings?...... if yes then chek on/off switch tracks... if no.... reball upp reball flash change upp... all b fine............ br |
04-27-2007, 13:09 | #7 (permalink) |
No Life Poster Join Date: Nov 2006 Location: INDIA(GUJRAT,RAJKOT) Age: 37
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | i chack all things i cahack power switch , power switch track all r ok when i conect ufs and make initial normal moad is om and i tride to power on/off it is working but when i insert battry phon dosent switch on FIRST PHONS PROBLEM IS when i go at "go to" menu phon is restart my phone is very clean and un dameged i flashed with ver 5.0,5.4,6.0,6.11 but no result masters plese help i am very confused plese help thanks in advance |
04-27-2007, 17:13 | #8 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Lahore, Pakistan
Member: 234653 Status: Offline Thanks Meter: 83 | 33100 power way Quote:
if not show charging then again full flash the set it will be ok... Hafiz Mobiles | |
03-07-2008, 18:55 | #11 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48755 Status: Offline Thanks Meter: 30 | i have a similar situation with 3100 and when i check the resistivity between + and - pins af the battery conector i find 3.5kohm in + --> - direction and 2KOhm in the other direction so do someone have an idea? |
6600 flash ok not switching on | karnataka | Dct4Direct | 10 | 06-26-2009 09:24 |
nokia 1100 flashes ok No switch on | nellabe | Nokia Hardware & Hardware Repair | 3 | 12-10-2007 19:04 |
3120 flash ok doesnt switch on | sharpgsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 08-21-2006 05:12 |
T610 flashes but not switch on | Alkapone | Sony Ericsson Hardware Repair | 29 | 05-17-2006 15:55 |
8250 flashes but not switches on | Bohosh | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-05-2004 22:28 |
