Old 01-22-2006, 14:10   #1 (permalink)
Member: 201127
Thanks Meter: 7
3100 - if you put battery in all lights turn on!
Hi everyone,
I have a 3100 which when a battery is put in it, all the lights come on automatically!
The phone has been previously water damaged.
I have tried with different screens and the top LCD connector / light controller is not damaged.
The phone does not do anything else! Just lights up when a battery is put in.
Any ideas?!
Thanks,
Chris.
Old 01-22-2006, 15:57   #2 (permalink)
Member: 41976
Thanks Meter: 33
hi mate!
i think u need 2 put ur fone in a solid bath.reflow the board n flash the fone.
good luck.
Old 01-22-2006, 17:36   #3 (permalink)
Member: 21937
Thanks Meter: 279
if phone is water damage you need to clean and reflux with hot air station.
seem like a cpu making problems
Old 01-23-2006, 09:28   #4 (permalink)
Member: 223612
hi
i have the same problem. the problem is in the flash there 2 solutions:
- clean the area and reflux with hot air
- if have n't anythink you must replace the component
Old 01-23-2006, 17:11   #5 (permalink)
banalven1's Avatar
Member: 202941
Thanks Meter: 85
maybe the coil problem,just change it n try~~~~~~~~~~~~~
Old 01-23-2006, 21:35   #6 (permalink)
naughtycell's Avatar
Member: 214350
Thanks Meter: 18
@banalvent1 , wich coil you mean plz ?
Old 01-24-2006, 03:36   #7 (permalink)
banalven1's Avatar
Member: 202941
Thanks Meter: 85
change (L300),problem still same plz check (N300)
hope can help~~~~~~~~~~~~~
Old 01-24-2006, 20:42   #8 (permalink)
Member: 214350
Thanks Meter: 18
This is not a light driver problem , the phone doesn't work at all . this problem is a UEM problem from water damage , the man need to raise the UEM and clean well , reball it reinstall . that prosses may be repeated for UPP and combo flash too .
If you looking for Vendor ID or IMEI on Blackberry Storm 9500 alexwood2000 BlackBerry (RIM) 1 02-27-2009 22:15
L6 Dead, Keypad light turns on for 5 sec. Ayush Smart-Clip 3 10-31-2008 09:37
if you are strong in GSM help me ali25 E-Gold Based Phones 6 10-05-2004 22:58
3310 lights turns on/off randomly kojote Nokia Hardware & Hardware Repair 13 07-02-2004 13:54
If You vont lg6 in C55V24! hallo E-Gold Based Phones 0 01-21-2004 20:25
Page generated in 0.28447 seconds with 8 queries
