Old 01-31-2005, 17:01   #1 (permalink)
Member: 112071
Thanks Meter: 5
3410 nokia charging ok but no power
pls help .
i have a 3410 nokia .it charges ok and will power when charger is plugged but will not power when charger is removed.i have serviced the board and checked battery connector but no result.thanks
Old 01-31-2005, 21:50   #2 (permalink)
^PAX's Avatar
Member: 82980
Thanks Meter: 23
look at on/off button, maybe damage .change it .
Old 02-01-2005, 01:11   #3 (permalink)
Nabil3H's Avatar
Member: 17675
Thanks Meter: 18
try to flash full backup after
try to change CCONT "90%"
Old 02-01-2005, 01:17   #4 (permalink)
Member: 38922
Thanks Meter: 35
First Update and reflow Ccont, if not ok, check this out:
GreetZ
Old 02-01-2005, 01:21   #5 (permalink)
Nabil3H's Avatar
Member: 17675
Thanks Meter: 18
This solution if the phone not power on "if it charge only"
but in this case it power on if the charger is connected
Old 02-01-2005, 01:24   #6 (permalink)
Member: 38922
Thanks Meter: 35
I already wrote: After check CCONT..
GreetZ
Old 02-01-2005, 02:14   #7 (permalink)
xchris's Avatar
Member: 8490
Thanks Meter: 27
check this...marked with red.
Old 02-02-2005, 17:05   #8 (permalink)
Member: 32127
Thanks Meter: 34
helpful opinion from xchris....u cud also consider to reball/replace the ccont as cyberoptik suggested
Old 02-02-2005, 18:30   #9 (permalink)
Member: 112071
Thanks Meter: 5
nokia 3410
thankx chris but what do i do with the red 'R'.do i remove completely or replace.thankx in advance
Old 02-06-2005, 01:21   #10 (permalink)
Member: 97043
Thanks Meter: 29
you should replace .......but u have to read it first
Old 02-06-2005, 01:23   #11 (permalink)
Member: 97043
Thanks Meter: 29
here is another simple way ,,,if u dont want to remove the v202 ..........just use a thin small wire and connect with ur 2.8v ..........but make sure u connect from the bottom of the switch.......and it will work 10000000%..
Old 02-06-2005, 01:28   #12 (permalink)
SALLAM's Avatar
Member: 92061
Thanks Meter: 3
gooood wooooooork
hodafone ................
Old 02-09-2005, 19:24   #13 (permalink)
Member: 112071
Thanks Meter: 5
3410 charging ok but no power
thanks segun but what switch are u referin to
Old 02-10-2005, 11:50   #14 (permalink)
Member: 82155
Thanks Meter: 33
is it the first component in the red mark or the second one we connect with the switch
Old 02-16-2005, 11:00   #15 (permalink)
Member: 83893
what should look for when phone powers up sometimes then the switch off menu appears on display...looks like faylty on off switch but already changed several , changed the capacitor and the resistor near the rf shielding on top right... changed v202...any ideas?
nokia n70 chargeing ok but no power on san9090 Nokia Base Band 5 ( BB-5 ) 10 05-21-2011 09:50
nokia 6680 charging ok but no power on tuban_gsm Nokia Hardware & Hardware Repair 3 02-02-2010 06:18
nokia 6300 charging ok but no power on qayyoom1 Nokia Hardware & Hardware Repair 12 06-01-2008 12:03
NOKIA 33XX-3410 Charging OK but No Power ON! <<SOLUTION>> CyberoptiK Nokia Hardware & Hardware Repair 2 11-24-2004 08:20
c55 charge ok but no power on thetunisiancrow E-Gold Based Phones 5 09-30-2004 14:53
Page generated in 0.32319 seconds with 10 queries
