Old 08-01-2006, 14:41   #1 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
6020 flashing ok but dead
Hi........... i got one 6020 its in dead condiation............... when we try to flash it it flash 100% but its still in dead condiation any clue............i also heat the board but still same............
waiting.......... thanks
Old 08-01-2006, 14:51   #2 (permalink)
gsm-iran's Avatar
Member: 188646
Thanks Meter: 76
6020 dead
u r problem nokia 6020
first u chack mob shotig after write flash with latesvertion file
when formet and ui siting
ok
thanks.............
Old 08-01-2006, 15:15   #3 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
after writing flash phone does not go in local mode...... and then this is not possible to do ui settings.............
i flash it with 4.01............
Old 08-01-2006, 20:53   #4 (permalink)
kaisar's Avatar
Member: 74776
Thanks Meter: 3
Try upgrade version first, if not work try to reheat IC Flash n UEM.
Old 08-01-2006, 21:40   #5 (permalink)
ics_igrec_zet's Avatar
Member: 55427
Thanks Meter: 7
REHEAT ONLY IF IC`S ARE NOT GLUED
BR, xyz
Old 08-01-2006, 22:03   #6 (permalink)
Member: 323176
U Dont **** The If Ic Because U Had Flashed.it Means That The If Ic Is Ok.so U Have Only Two Choices To Rectifi The Problem.the One Is Changing Flash Ic Other Is Changing Processor.
Today I Ready The Same Problem By Changing Processor
Old 08-02-2006, 02:23   #7 (permalink)
Member: 96184
Thanks Meter: 6
check the energy managment values before you heat the board. if the battery voltage level is really high then you need to correct by copying the em values from a working 6020 and write to your faulty 6020 using phoenix.
6020 flashing ok but normal mode failed rinku24 Nokia Hardware & Hardware Repair 6 11-29-2008 07:48
3200 (RH-30) Flash Ok but Dead goga3000 Nokia Digital Core Technology 4 ( DCT-4 ) 5 04-25-2006 19:35
3310 dead can flash ok but dead mobilemafia Nokia Hardware & Hardware Repair 12 06-02-2004 00:06
Page generated in 0.21614 seconds with 9 queries
