Old 09-27-2005, 11:30   #1 (permalink)
yandbass's Avatar
Member: 101268
Thanks Meter: 119
3100 no.5 not working
No.5 not working in my set. Could anyone help with the track solution.
Old 09-27-2005, 17:34   #2 (permalink)
sumeda's Avatar
Member: 71960
Thanks Meter: 5
i think one line goes to ground and other one goes to upp.
check with working pcb will help you more.
br.
Old 09-27-2005, 17:37   #3 (permalink)
sumeda's Avatar
Member: 71960
Thanks Meter: 5
i think one line goes to ground and other one goes to upp.look like no component connect to those lines.if ur ground line ok then u have to work with upp test point.
br.
Old 09-27-2005, 18:18   #4 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 814
peel back keypad membrane and clean board. reassemble and try..
also check if keypad is making good presure on membrane...
test continuity of outer ring of keypad to ground. if no continuity, you can join that out ring to next key outer ring..
Nokia 3100 Keypad 5 Not Working alex1205 Nokia Hardware & Hardware Repair 12 10-28-2011 02:03
Need Help Nokia 3100 Key No 5 Not Working aaronixsoni Nokia Hardware & Hardware Repair 19 09-26-2010 17:36
nokia 3100 no.5 key not working karthickpabks Nokia Hardware & Hardware Repair 7 07-26-2009 14:22
3100- loud speaker not working rahmanp Nokia Hardware & Hardware Repair 4 08-09-2008 19:22
3100 key # not work !!! dynamic-gsm Nokia Hardware & Hardware Repair 1 09-25-2005 13:57
Page generated in 0.28442 seconds with 8 queries
