08-29-2004, 19:46 | #4 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Riyadh, K.S.A. Age: 49
Member: 77205 Status: Offline Thanks Meter: 4 | try the other LCD... if same change the 1851 ic and the transformer... if same check the connections (use the multitester) check the continnuity of the connections... |
08-30-2004, 22:40 | #7 (permalink) | |
Freak Poster Join Date: Sep 2003 Location: Czech Rep. Age: 43
Member: 40423 Status: Offline Thanks Meter: 5 | Quote:
depends on problem... not all signal problems isn`t same... | |
09-06-2004, 19:15 | #8 (permalink) | |
Junior Member Join Date: Aug 2004
Member: 78639 Status: Offline Thanks Meter: 1 | Quote:
09-17-2004, 08:14 | #10 (permalink) |
Member: 40423 Status: Offline Thanks Meter: 5 | Wire solution u mean Jumper trick ?? replacing duplexer (antenna switch by wire isnt good repair) otherwise u will lost 1800mhz frequency. When u wanna hint to repair nokea 3310 signal, u must explain ur problem very well. coz there are too many parts in phone which can be damaged, and phone has no signal. (PA, COBBA, DUPLEXER, 1stVCO-crystal, Haggar, Filters...etc. even it can be broken track and so on.) Explain ur problem better. We will try to help you. Nokia 3310 signal problems aren`t same. U can not use only one solution to repair all without signal 3310`s. !!!And jeerich please post nokia network problems to right section . !!! Last edited by Yoda_Brno; 09-17-2004 at 08:55. |
09-17-2004, 14:22 | #12 (permalink) | |
Then follow this link. http://forum.gsmhosting.com/vbb/show...ht=3510i+light USE SEARCH FUNCTION | |
02-16-2005, 14:22 | #14 (permalink) |
No Life Poster Join Date: Jul 2003 Location: BahaMAS Age: 40
Member: 35975 Status: Offline Thanks Meter: 19 | ATT. AIRON6 Hi I have same problem on 3 3100's. Iv'e changed the 1851 and transformer but still same problem. The 1851 is same ic which is used on 6600 phones but I cannot find any relationship between the 2 phones. Any other ideas pls?? tonytony |
The Following User Says Thank You to TONYTONY For This Useful Post: |
02-16-2005, 14:26 | #15 (permalink) |
Member: 35975 Status: Offline Thanks Meter: 19 | btw 3100 had no liquid damage before, coil was s/c before replacing (good). Fault must be in backlight trigerring section, that is, a broken track which sends signal to 1851 to switch on b/l. tonytony |
k530i no light in display and keypad....... | sumeet922 | Sony Ericsson Hardware Repair | 8 | 07-31-2010 16:18 |
kg195 blank screen no light in screen and keypad help me | shani72 | LG Hardware Repair | 0 | 09-26-2009 07:11 |
E1 no lights on LCD and keypad.. need help please!! | ryumahon | Motorola Hardware Repair | 3 | 12-08-2007 11:42 |
3100 no lights on screen | rdf009 | Nokia Digital Core Technology 4 ( DCT-4 ) | 13 | 07-27-2007 08:00 |
3120 no lights in display and keypad | agent_gokiburi | Nokia Hardware & Hardware Repair | 8 | 07-22-2006 05:32 |
