Old 08-18-2009, 16:12   #1 (permalink)
Member: 254086
Thanks Meter: 24
Nokia2630 its faling to unlock
i have nokia 2630 from uk the SW is 06.82 so which box is supporting bcs with jaf is failing to unlock it
Thank u
The Following User Says Thank You to patelfaizu For This Useful Post:
Old 08-22-2009, 18:19   #2 (permalink)
Crazy Poster
Member: 53837
Thanks Meter: 9
i had same problem too
The Following User Says Thank You to swann For This Useful Post:
Old 08-22-2009, 18:22   #3 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
@patelfaizu
@swann
u can unlock it with MX-KEY.
test report here
Imei net: 35934202915537
Provider: Vodafone / Airtel Movil, Country: Spain
Counter: 0/3, 0/10
CONFIG_DATA: 2140100000000000
PROFILE_BITS: 800000000001000B
BLOCK 1: 1.LOCKED (MCC+MNC): 21401F
PhoneType:RM-298
SwVersion: V 06.82 26-09-08 RM-298 (c) Nokia
MCU file: rm298__06.82.mcusw
Trying to find patch position ...OK, case id: 4
ROM version: 4
ASIC ID: 0x3162 [UPP8M_v6.x]
u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 883C [ST] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000
u3_intel.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x56E8
Performing Flash Authentication ...OK
UEM ID: 001538AE:3B8ADA60
Area [01000000-0101FFFF] erased in 1.156 s
Area [01080000-0109FFFF] erased in 1.157 s
Programming ...
Programming completed.
Updating SIMLOCK ...OK
Area [01000000-0101FFFF] erased in 1.172 s
Area [01080000-0109FFFF] erased in 1.156 s
Programming ...
Completed in 47.140 s
Reading Simlock info ...
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
The Following User Says Thank You to himanshu taldar For This Useful Post:
Old 08-22-2009, 18:52   #4 (permalink)
Crazy Poster
Member: 53837
Thanks Meter: 9
yes.. tested by me
use mxkey
Old 08-22-2009, 18:53   #5 (permalink)
Crazy Poster
Member: 53837
Thanks Meter: 9
yes.. tested by me
use mxkey
Nokia E61i its supported to unlock? Curro MT-BOX 11 02-18-2008 09:19
Its possible to unlock Samsung C420 ? gsm_unlock2 UST Pro II 14 12-23-2007 21:23
samsung e315 its posible to unlock with twister forever Twisterflasher 9 03-18-2005 19:42
Page generated in 0.13878 seconds with 10 queries
