Old 12-28-2006, 22:47   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,230
..:3100 no network:..
3100 no network? in the circuit there are two flash ic....z, change PA,change hager? anyone have solution?
The Following User Says Thank You to HUM For This Useful Post:
Old 12-29-2006, 04:09   #2 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,406
Change Network Filters Many Times Tested
Archit Raj
The Following User Says Thank You to ..::ArchitRaj::.. For This Useful Post:
Old 12-29-2006, 06:08   #3 (permalink)
Member: 91180
Thanks Meter: 22
hi,
try to rehot uem work 100% for me many time.
The Following User Says Thank You to tejasr For This Useful Post:
Old 12-29-2006, 06:28   #4 (permalink)
Member: 418849
Thanks Meter: 2
yes i agree uem is the last choice....
The Following User Says Thank You to brakedown For This Useful Post:
Old 12-29-2006, 07:05   #5 (permalink)
Member: 401090
Thanks Meter: 4
try to change network filter,
if no lucks, reheat uem..
regards,
The Following User Says Thank You to +1.2.2patch+ For This Useful Post:
Old 12-29-2006, 07:49   #6 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
Thanks Meter: 405
here is step by step procesure..
1) reball or change mjolner
2) reball cpu
3) reball uem
4) change filters..
this is my way of repairing 3100 network... works for me all the time
try n post results
The Following User Says Thank You to .:KHALIFA:. For This Useful Post:
Old 12-29-2006, 16:19   #7 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,686
DO NOT MAKE ANT JEMPER IN 3100 1100 IT CAN DISTROY UR GSM RX FILTER r RX IC ALSO
THERE FOR U SHULD REPLACE YOUR DUPLEXER(ANT SW) 4 EVER
The Following User Says Thank You to imran zafar For This Useful Post:
Old 12-29-2006, 18:14   #8 (permalink)
Member: 177580
Thanks Meter: 6
check rf key component placement for example z601,z604,g701,n601,b601,z603,z602,n801,z701 rehoot or reball.good luck my friend
The Following User Says Thank You to kostask For This Useful Post:
Old 12-29-2006, 22:51   #9 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,230
Archit Raj
mr.architraj, in my set no signal at all,no signal means not a single signal, i already change filters but still same?
Old 12-30-2006, 04:23   #10 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,230
can plz anyone clear why in my 3100 circuit there are two flash ic?
Old 12-30-2006, 19:27   #11 (permalink)
Member: 275631
Thanks Meter: 405
two flashes... dont bleaive .... add picture
Old 12-30-2006, 19:30   #12 (permalink)
Member: 374225
Thanks Meter: 41
their cant b 2 flash ics bro this is 4 the first time im hearing this well u dnt have to touch ur flash also jst change mjoelner and flash it with latest ver it will work 4 u also check if antinna pin in body case touching the pcb antinna hole or not or make jumper their
The Following User Says Thank You to pdapower For This Useful Post:
Old 01-01-2007, 00:58   #13 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,230
wat is mjoelner....?plz tell me?its urgent? as the members said rehot uem,i rehot and reball uem,but it still in no network position?not showing signal a single time?and plz tell me if i use..::7250i,6230 hager ic and pa,it works or not in nokia 3100::..?which other model hager and pa works with 3100?plz read my post and give full answers?plz check attached pic?i marked in this picture....!plz check its urgent!!!!
The Following 5 Users Say Thank You to HUM For This Useful Post:
Old 01-01-2007, 05:36   #14 (permalink)
Member: 275631
Thanks Meter: 405
man r u new to hardware.... coz with 398 posts u shouldnt b asking these silly questions............ any ways.... mjolner is hagar.....no u cant u 6610,7250, helga..... models in which u ill find mjolner n P.A. r .... 3650/60, 6600,3100/20,1100,2300,2600,ngage QD,6100.
90% pa n antena swicth r not the faulty part.... its always from mjolner(hagar) or uem.
2) reball cpu
3) reball uem
4) change filters..
try n post results
Old 01-01-2007, 11:30   #15 (permalink)
Member: 418843
well u should try out this method n post me the result
1. first change rx filter
2. reball or change hagar
3. change clock crystal
4. reball uem
i have tested it many times and believe it is a 100 % solution.
The Following User Says Thank You to meet_2007 For This Useful Post:
The No. 1 Pass Under the Heaven -- Shanhai Pass (?????-???) (box packing VCD) (China) IPMART ipmart WebShop 0 03-29-2010 14:00
Genie dead no power on... [ANSWERED] lchico Genie Universal 1 03-29-2010 07:18
Could Not Activate Cellular Data Network: You Are Not Subscribed to a Cellular Data gugutm iPhone 2 / iPhone 3G / iPhone 3GS 1 10-02-2009 17:25
!!! NO ACCESS / NO NETWORK: 4 PA's CHANGED, 4 FAILURES !!! dannyogolo Sony Ericsson Hardware Repair 6 07-26-2004 11:16
network: 000 00 ReviveR Nokia Hardware & Hardware Repair 13 07-20-2004 21:25
Page generated in 0.41099 seconds with 9 queries
