08-16-2005, 16:15 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: United Arab Emirates Age: 43
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | 3100 No signal solution |
01-09-2006, 06:14 | #7 (permalink) | |
Freak Poster Join Date: Nov 2005 Location: Malaysia Age: 43
Member: 202941 Status: Offline Thanks Meter: 85 | Quote:
01-10-2006, 16:37 | #11 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 52
Member: 54993 Status: Offline Thanks Meter: 47 | Sometimes small tricks work fine. Replace working antenna with your phone. OR test your PCB in another working phone. you will get good result. I've faces this type of problem in several 3100. Solved many of them by this solution only. |
The Following User Says Thank You to rajumobile For This Useful Post: |
01-10-2006, 19:07 | #12 (permalink) | |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | Quote:
01-11-2006, 01:08 | #13 (permalink) | |
Freak Poster Join Date: Dec 2005 Age: 44
Member: 214350 Status: Offline Thanks Meter: 17 | Quote:
02-10-2006, 02:10 | #15 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: cebu Age: 43
Member: 164237 Status: Offline Thanks Meter: 12 | Quote:
what i do with it is try to re hot first the mjolner/signal processor ic or better replace it.. usually most dct4 signal processor ic are the main problem if no network found with long searching period..if it has shorter searching period then no network, its probably the VCO,. if drop signal or no access, PA or antenna switch B.R. | |
The Following User Says Thank You to goffaman For This Useful Post: |
Nokia 3100 No signal | floky | Nokia Hardware & Hardware Repair | 5 | 07-24-2007 13:18 |
nokia 3100 no signal what is the probleme.... | faisi | Nokia Hardware & Hardware Repair | 4 | 07-24-2007 13:16 |
3100 No signal-ST_TX_IQ_DP_LOOP_TEST | traxdata2003 | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 01-04-2006 11:25 |
3100 no signal | swand | Nokia Hardware & Hardware Repair | 2 | 02-07-2005 00:55 |
3100 NO SIGNALS need help ????? | mark3 | Nokia Hardware & Hardware Repair | 4 | 12-23-2004 09:54 |
