Old 05-19-2006, 14:12   #1 (permalink)
erkan06us's Avatar
Member: 174769
Thanks Meter: 19
3100 Power Off After 15 Sec.
hi friends.i ve a 3100.when it power on ,its power off after find network 15 sec.i did full erase and write full flash and imei again.the problem didnt solve.i changed the uem and wirte all again.but there s still same problem.i rehoted cpu and flash too.what can i do for solve my problem.could you help me,?
Old 05-19-2006, 14:31   #2 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
3100
change uem ............................................
Old 05-19-2006, 17:46   #3 (permalink)
Member: 243881
Thanks Meter: 68
chang the power sw
I CAN DO THAT
Old 05-19-2006, 17:53   #4 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
replace PA and have a nice phone
Old 05-20-2006, 01:35   #5 (permalink)
wei
Member: 277791
rebuit the cpu.flash ic also got effect
Old 05-20-2006, 05:10   #6 (permalink)
Member: 62321
Thanks Meter: 35
to solve this ..
1st be sure that UEM is good if u dont know chane NEW UEM and write RPL ASC2
2nd change power amplifer (PF)
ur problem will solve
Old 05-20-2006, 05:14   #7 (permalink)
Member: 277263
in 3120 after 15 sec.power off so i have taken flash ic, its rebowling the flash ic & attached to 3120 & also with software but problems are second boot error so what can i do solve my problem
Old 06-09-2006, 15:09   #8 (permalink)
erkan06us's Avatar
Member: 174769
Thanks Meter: 19
i did all what you said.still same problem same problem.phone power off after 30 sec.
Old 06-10-2006, 03:08   #9 (permalink)
sallupat's Avatar
Member: 138982
Thanks Meter: 138
@ erkan06us
first you had to check the handset with the new battery. if problem remani the same just change the PF. because when the network receive in the handset after switch on there is maximum power consumption. so plz try with the less risky solution. & also check the battery connector
Old 06-24-2006, 07:24   #10 (permalink)
erkan06us's Avatar
Member: 174769
Thanks Meter: 19
i solved my problem.must use new uem,not used.when i use new uem and write rpl my problem was solved.thanks to all.
Old 07-09-2006, 09:15   #11 (permalink)
ashrafcell's Avatar
Member: 232622
Thanks Meter: 17
change uem write imei good work
Old 07-09-2006, 11:53   #12 (permalink)
Member: 137686
Thanks Meter: 3
Cool
try to replace UEM ic and PA ic may be can solve u'r problem. have a nice day
Old 07-09-2006, 16:17   #13 (permalink)
Member: 97502
Thanks Meter: 4
thanxxxxxxto all 4 goodwork
Old 07-09-2006, 16:23   #14 (permalink)
baywalker's Avatar
Member: 260002
Thanks Meter: 8
change your flash IC and flash it again
Old 07-09-2006, 16:35   #15 (permalink)
shahzadlinks's Avatar
Member: 155330
Sonork: 100.1585247
Thanks Meter: 7
change the uem then same time off or enter the sim off change the pa
1100 power off after 30 sec Sagitarious Nokia Hardware & Hardware Repair 16 06-22-2010 21:00
3100 power off after few sec mmanduri UFS2 + UFS3-Tornadoflasher 3 08-17-2006 08:57
SL55 when Dor is open phone worked IF closed powered off after 20 sec solution MaFiaaa Siemens Hardware Repair Area 7 02-27-2005 20:21
8310 imei showing ?????????¤ and power off after few sec! Gsmhq Twisterflasher 3 11-03-2004 21:15
6510 powers off after 30 sec. Byte Nokia Hardware & Hardware Repair 8 07-14-2004 05:56
Page generated in 0.21824 seconds with 10 queries
