Old 03-10-2007, 13:39   #1 (permalink)
Member: 296067
Thanks Meter: 50
3100 show problem
sir see what ic promblem,thk
Old 03-10-2007, 13:44   #2 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
i think your problem is upp
1. reball the upp
2. change the upp
your problem solve
b,r
yuvi,
Old 03-10-2007, 15:44   #3 (permalink)
rana_sab's Avatar
Member: 62911
Thanks Meter: 156
some time cable not connect properly with handset that why you got this type of error
try to clean the flashing points if problem still there then try to connect the cable with only circute bord
otherwise rehot the uem first then rehot upp
Old 03-10-2007, 16:25   #4 (permalink)
shell24's Avatar
Member: 418253
Thanks Meter: 42
I think, mobile is not boot up
1. check cabel conection to board.
2. check All Vbat to UEM
3. Check PURX on J402 (if switch pressed should be ~3V)
4. check 26MHz clock from RF IC
if all OK, cabel conection problem
sHELL24
Old 03-11-2007, 03:12   #5 (permalink)
Member: 296067
Thanks Meter: 50
thk all bro,set is ok now.
Old 04-09-2007, 09:36   #6 (permalink)
aboymaligalig's Avatar
Member: 460316
Thanks Meter: 22
sir kindly help on 3100 water damage. i flash the fhone using jap the program is good but when i put the battery' the fhone doesnt turn on and local mode apper on the scren
Old 04-09-2007, 09:42   #7 (permalink)
..::GSM329::..'s Avatar
Member: 477733
Thanks Meter: 73
Check voltage to power swith if 3.8V. press down to 0.0V. checking UPP.
If press pw.sw. not down to 0.0V. change pw.sw.
Lucky.
Old 04-09-2007, 10:07   #8 (permalink)
Member: 350571
Thanks Meter: 920
change this crystel ur problem will be solve
Old 04-09-2007, 12:21   #9 (permalink)
Member: 350948
Thanks Meter: 32
Look same problem is given in forum with picture , U have to remove Two res which near to battery connector, It will work 100%
3100 shows Phone Restricted Enter code ..:MumbaiGsm:.. Nokia Hardware & Hardware Repair 5 06-03-2010 10:56
3100 show problem gpong Nokia Hardware & Hardware Repair 7 09-08-2007 14:48
3100 shows not charging by itself without charger hooi76 Nokia Hardware & Hardware Repair 10 06-27-2007 02:06
3100 showing local mode kulu Nokia Hardware & Hardware Repair 3 03-24-2005 14:07
3100 shows not charging Yoda_Brno Nokia Hardware & Hardware Repair 5 03-04-2005 15:48
Page generated in 0.21488 seconds with 11 queries
