01-27-2007, 06:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 403881 Status: Offline Thanks Meter: 80 | 3100 Showing Only Charging Bar |
01-27-2007, 11:17 | #2 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 47
Member: 101007 Status: Offline Thanks Meter: 27 | tis would be your phone hang can be cause by so maqny part... normally should flash the phone but since ur cuz wan the memory u can try mjoitner first reheat reball or replace tis ic fault can cause not only network but hang as well if tis does not solve ur prob try upp reheat reball or replace... happy trying regards |
01-27-2007, 11:36 | #4 (permalink) |
Junior Member Join Date: Jan 2007 Location: rajkot-(india)
Member: 427330 Status: Offline Thanks Meter: 0 | only charging bar when sim inserted man thats 100% problem of software problem, i made several phone like 3100 - 6610 - 7250 - 7210 with this problem replay me if you successful to solve this problem |
01-27-2007, 21:20 | #9 (permalink) |
Junior Member Join Date: Nov 2005
Member: 200467 Status: Offline Thanks Meter: 12 | if ur using ufs try this to save the contact.connect the phone and click on (write user seting).u will get a option save a file with extension .pp.save the file.Now flash the phone and write the save file back all ur contact will b restored. |
01-27-2007, 23:18 | #10 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Gujjar AJK
Member: 207308 Status: Offline Thanks Meter: 471 | using full erase and full flash with cnt file mustly and write processor pm other wise reball/heat the upp remember mustly use processor pm file not only simple pm ok tested bt me 1000000%ok |
01-27-2007, 23:32 | #13 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | bro as i know,this is uem problem,bcoz i face same problem in 6100,i resold all ic accept uem bcoz it is sealed!i m not sure but i think so. |
01-28-2007, 07:06 | #14 (permalink) |
Member: 403881 Status: Offline Thanks Meter: 80 | Thank U very much for sharing your experience but i would like draw your attention towards main problem, that is customer needs his contact if we can save the contacts in this process than I will try.REGARDS WAITING FOR YOUR REPLY |
Ztc a898 shows only charging after complete format | bhogpurmail | Infinity-Box | 4 | 05-26-2009 22:27 |
G600 show only Charging | rana_sab | Samsung Hardware Repair | 4 | 11-24-2008 06:43 |
3100 shows not charging by itself without charger | hooi76 | Nokia Hardware & Hardware Repair | 10 | 06-27-2007 02:06 |
9210 show only charging | irfaN_vu | Nokia Hardware & Hardware Repair | 3 | 06-23-2005 17:39 |
3100 shows not charging | Yoda_Brno | Nokia Hardware & Hardware Repair | 5 | 03-04-2005 15:48 |
