3100 shows not charging by itself without charger 3100 shows not charging by itself suddenly without the charger. I already reflash the whole phone and then patch imei. May i know what is the problem? :confused: :confused: :confused: |
3100 not charging 2 Attachment(s) You can take help from these pictures. |
at times the problem as to do with the fuse. try changing fuse or short circuit |
@ hooi76, pls. try to clean pcb with ultrasonic cleaner wbr |
hai for 3100 when we connect the charger it shows not charging any solution ? |
i already clean the phone, and i reball the cpu too, the lcd still show the [not charging]. and worst is after reballing the cpu, sometimes the other party can not hear from my voice. is it UEM problem that causes the phone shows [not charging] WITHOUT CHARGER. and now other party can not hear my voice. is this also related to UEM too? |
@ hooi76, now all is clear. pls. check voltage at battey connector with charger pluge in and without battery. if there is 3.6 volt. then just change UEM. and after procces, all problem will be solved. wbr |
yes hooi76 this is uem problam rebaall or change uem |
nokia3100 not charging on dispay it's either uemor v100 problem Quote:
hot the uem today (maybe dry solder) and untill now, the phone works normal again, will post results again tomorrow. thanks everbody. |
today i have another 3100 water damaged phone, I already clean the pcb, reball the CPU, UEM, Flash IC, MJOLNER and PA. CHnage the buzzer ic cos it;s burnt. And now it shows not chanrging by ITSELF too. What is the problem? Please help. |
