06-13-2006, 03:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | 3100 shows not charging by itself without charger |
06-14-2006, 11:18 | #6 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | i already clean the phone, and i reball the cpu too, the lcd still show the [not charging]. and worst is after reballing the cpu, sometimes the other party can not hear from my voice. is it UEM problem that causes the phone shows [not charging] WITHOUT CHARGER. and now other party can not hear my voice. is this also related to UEM too? |
06-14-2006, 11:27 | #7 (permalink) |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | @ hooi76, now all is clear. pls. check voltage at battey connector with charger pluge in and without battery. if there is 3.6 volt. then just change UEM. and after procces, all problem will be solved. wbr |
06-14-2006, 12:04 | #8 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Uttaranchal Age: 35
Member: 181696 Status: Offline Sonork: 100.107830 Thanks Meter: 5,406 | Quote:
yes hooi76 this is uem problam rebaall or change uem | |
06-27-2007, 02:06 | #11 (permalink) |
Member: 7741 Status: Offline Thanks Meter: 111 | today i have another 3100 water damaged phone, I already clean the pcb, reball the CPU, UEM, Flash IC, MJOLNER and PA. CHnage the buzzer ic cos it;s burnt. And now it shows not chanrging by ITSELF too. What is the problem? Please help. |
Solution Of Reconnect Charger or Charge By Itself. For 3310 | keany | Nokia Repair Guide and FAQ | 220 | 03-27-2011 08:02 |
chinese n95 8gb shows usb config and charges by itself | vlatche_mk | Chinese Models & Cloned Phones | 0 | 04-05-2009 14:30 |
HELP Solution for 1100 reconnect charger or charge by itself ? | sapatos | Nokia Hardware & Hardware Repair | 2 | 08-27-2005 10:33 |
3100 shows not charging | Yoda_Brno | Nokia Hardware & Hardware Repair | 5 | 03-04-2005 15:48 |
Nokia 3610 show not charging when connect with charger | TechPhone | Nokia Hardware & Hardware Repair | 2 | 01-27-2004 20:29 |
