06-29-2007, 22:56 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::3100 signal fall down when display light off::.. |
06-29-2007, 23:00 | #2 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
reball UEM ,tested in many set | |
06-30-2007, 05:55 | #6 (permalink) |
Freak Poster Join Date: May 2006 Location: INDIA Age: 46
Member: 280630 Status: Offline Thanks Meter: 18 | It's Not A Uem Problem, On S/w Side Firstly Flash With A Good Pm & Then Check Your Tx Line Clearly Bcos This Fault Is Related To Only Tx Section Jumpering Ant Sw In 6610 & 3100 Is Not An Intelligent Task Bcos In Tx Line Both Handsets Have A Filter Inductor Coil So Making It Jumpered Will Cause The Signal To Be Grounded So Beware About That |
07-01-2007, 00:47 | #9 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | i reball uem, change meljoiner, change filters, change pa all conponents taken from ok set, still cant found the solution, already write full pm? |
J300 i no audio after fall down... | uti79 | Sony Ericsson Hardware Repair | 3 | 05-20-2008 05:36 |
nokia 6030 hang when display lights off | imran ud din | Nokia Hardware & Hardware Repair | 2 | 01-17-2007 19:09 |
2100 display light off and signal gone | HUM | Nokia Hardware & Hardware Repair | 3 | 12-20-2006 11:33 |
samsung e700 green screen in camera mode after fall down onto the ground | charliej | Samsung Hardware Repair | 1 | 08-27-2004 18:50 |
no vibrating alert on T28 after falling down | HELIOSS_RISALA | Old Ericsson Phones & Sony Phones | 6 | 09-06-2001 17:20 |
