Old 11-07-2007, 08:58   #1 (permalink)
Member: 248245
Thanks Meter: 85
3100 speaker not working
Hi mates 3100 speaker not working set is work fine speaker ok i think a special file for flashing required due chinese mother board if any one have this file kindly upload and tell me way of uses with UFS.
Old 11-07-2007, 12:38   #2 (permalink)
Dream Asia's Avatar
Member: 490426
Thanks Meter: 250
First,u have 2 check the ringer ic.reball or change.
if it also cant slovd ur problem..
reball the UPP...
100% solved ur problem...
Old 11-07-2007, 13:00   #3 (permalink)
Member: 390858
Thanks Meter: 29
check the following picture
check the following picture,it might help
Old 11-07-2007, 13:28   #4 (permalink)
Member: 248245
Thanks Meter: 85
bro this is not hardware it is software becoz that is china mother board so this board required special file for flashing.
Old 11-15-2007, 11:07   #5 (permalink)
Member: 218793
Thanks Meter: 29
it is not hardware its software problam when we convert 3100b to 3100 then speaker not work so we neeed speacial pm file
Old 11-15-2007, 16:03   #6 (permalink)
Member: 248245
Thanks Meter: 85
you are right bro it is a special PM file but i have not this file any one have pls upload thanks.
Old 11-15-2007, 17:13   #7 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
Zakir375 '
Problem associated with speakers -
1. speaker not properly positioned .
2. speaker broken .
3. mobile phone had a broken leading to speaker position.
4. speaker can be switch off from setting .
solution s -
1. this is hardware soultion to your mobile phone problem.
2. check if speaker is still present .
3. check if speaker is not broken or still ok.
4. check if speaker have moved positions .
5. check if your mobile phone casing is properly closed.
6. check if interface between speaker and board is contacting .
7. check if dirt are found between interface .
8. check if earpiece provided for the user is not blocked by any substance.
solution
1. replace earpiece or speaker. if any available.
2. clean all contact interface both earpiece and mobile phone board.
3. check if mobile phone volume is turned off or low.
thank 's
Bestman
Old 11-20-2007, 20:59   #8 (permalink)
Member: 248245
Thanks Meter: 85
Originally Posted by bestman View Post
Zakir375 '
2. speaker broken .
solution s -
solution
thank 's
Bestman
bro this is software problem set working fine, press any key given sound only PM file needed that's problem solved here in my city someone have this file and repair many set but this man not disclosed particular file, i think you now understand, any way thanks for your kind solution.
Old 11-28-2007, 14:24   #9 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
its not software problem 1 phone dead by me i tried many pm's maany flashed errased set dead simply its UPP fault reheat or change it
Old 11-29-2007, 03:52   #10 (permalink)
kanwal's Avatar
Member: 496736
Thanks Meter: 17
it is new for me thanks for posting
c6000 speaker ways loudspeaker working but ear speaker not work shani72 Chinese Models & Cloned Phones 3 06-19-2011 06:54
1200 speaker and way ok but speaker not working why ?????????????????????????? tiju kkm Nokia Hardware & Hardware Repair 11 04-07-2010 01:19
2310 speaker not working but loud speaker working? albert139 Nokia Hardware & Hardware Repair 5 05-25-2009 21:19
3100- loud speaker not working rahmanp Nokia Hardware & Hardware Repair 4 08-09-2008 18:22
Page generated in 0.19281 seconds with 10 queries
