10-31-2007, 07:35 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Hyderabad, INDIA Age: 48
Member: 379342 Status: Offline Thanks Meter: 16 | 7610 white screen I have repsoldered display connector I have replaced display filter I have flashed the handset . But the problem is same. |
10-31-2007, 11:08 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | 1..brthr if ur set make call s or it have voice in speker when we press butoon then there is problem in display,display ic.,display connector....... 2.. brthr if it is not doing this as i give inf about you in 1 first erase the phone flash and then flash the phone with jaf.... if then not solve then change boot ic ...... if not solve then reball uem...... if not solve then problem in upp..... |
10-31-2007, 12:27 | #3 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: In Front All of You Guys
Member: 166078 Status: Offline Thanks Meter: 21 | Quote:
B.R "DOGLAG" | |
10-31-2007, 22:59 | #6 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | hi, it's a 100% lcd case....some times can possible to repair lcd re hot lcd left side is lcd ic hit that ic very care fully….may be your lcd problem solved…if not ok then check with new lcd. Then you get the result…….good luck |
11-30-2007, 15:26 | #7 (permalink) |
No Life Poster Join Date: Oct 2007 Location: nigeria
Member: 601591 Status: Offline Thanks Meter: 86 | hi my brothers pls just look at display ic they are two there carefully change the big one aalso av very small beside remove it and bridge both left n right sides leave the middle one that one is ground so try to check them true the lcd connector if they connect if not he cannot display so that is the best solution i hv use this method for more many many 7610 and it work perfect i dont av any diagram i would hv giving you dis my mobile no +218928502905 wishes u best of luck |
7610 white screen | nasir shiwani | Nokia Hardware & Hardware Repair | 46 | 02-16-2010 06:22 |
7610 white screen all calls incoming outgoing flashed many version still white screen | GSMBALOCH | Nokia Hardware & Hardware Repair | 7 | 06-01-2009 20:54 |
7610 White Screen then Turns off, Urgent | msas | Nokia Hardware & Hardware Repair | 8 | 11-15-2006 03:34 |
7610 white screen after flashing a ppm | MELME | UFS2 + UFS3-Tornadoflasher | 29 | 05-05-2006 01:53 |
