Old 02-06-2006, 12:41   #1 (permalink)
Member: 64472
Thanks Meter: 14
3100no voice
hi every one how r u all need ur help i have a 3100 after flash no sound no speaker phone tried lots of versions loys of pm files after reading d threads but no solution can someone tell me the right solution n its not hardware problem pls need help its very urgent thnx in advance
Old 02-06-2006, 16:44   #2 (permalink)
amps_jas's Avatar
Member: 218135
Thanks Meter: 7
flash it with v6.11 man!
Old 02-06-2006, 22:36   #3 (permalink)
Member: 228420
Thanks Meter: 3
ok and thanks youuuuuuuuuuuuuuuuuuuuu
Old 02-07-2006, 10:04   #4 (permalink)
Member: 64472
Thanks Meter: 14
soory but not working with that 6;11 version any other software solution n i solved it with changing d cpu n flash after that works fine now but there should b some software solution also if some one have so pls share with others also thnx
Old 02-07-2006, 20:26   #5 (permalink)
Member: 195236
Thanks Meter: 4
speaker
Speaker change
Old 03-25-2006, 15:43   #6 (permalink)
Member: 91180
Thanks Meter: 22
hi,
this problem is from cpu try to rehot it with small amount of flux
Old 03-25-2006, 16:26   #7 (permalink)
smorbe's Avatar
Member: 132735
Thanks Meter: 88
i know a solution for that.
Do this...
100% software problem.
This solution works with all asic2 with that problem... (no earpiece in calling)
3100b flash file must be installed.
Open UFS_Dctx....
Select (3100b) regardless of phone you were repairing
click (check) phone must be detected
click (write pp)
click rh50*********.***
remove cable...
enjoy.
post result.
Old 03-26-2006, 14:33   #8 (permalink)
Member: 168615
Smile
yes i agree with smorbee....
Old 04-19-2006, 09:50   #9 (permalink)
Member: 260823
Thanks Meter: 11
i have nokia 6610 no spk&mic chanced uem but same problem can some body help with diagram
Old 06-10-2006, 12:35   #10 (permalink)
Member: 269883
Thanks Meter: 18
salut
i have the same problem
i flashe the 3100 with version 6.11 and result no sound (no speaker no mic)
i tested the solution of mr smorbe i worked 100%
thanks mr smorbe
tank u very much
merci beaucoup
Old 10-11-2007, 10:38   #11 (permalink)
Member: 543425
Thanks Meter: 7
Double Salut
I have 3100 no mic & speaker i tested it and its not hardware prob. i already reball upp & uem still did not work but when i flash it with version 6.11 it works 100%... thnx smorbe thnk u very men....
Old 10-11-2007, 10:39   #12 (permalink)
Member: 543425
Thanks Meter: 7
Double Salut
I have 3100 no mic & speaker i tested it and its not hardware prob. i already reball upp & uem still did not work but when i flash it with version 6.11 it works 100%... thnx smorbe thnk u very much men....
Old 10-11-2007, 16:18   #13 (permalink)
Member: 244357
Thanks Meter: 70
flash 6.11 your problem will be solved
Old 04-19-2008, 19:36   #14 (permalink)
Member: 209820
Thanks Meter: 3
if after antena switch no mic no sound
it's soft or hard
please help me
Old 04-19-2008, 20:05   #15 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
it's soft or hard
please help me
" ur post is not clearly mentioned, make it clear bro, so that u get the best replies"
voice SMS send voice sms messages from mobiles aapkae Nokia Multimedia 1 04-12-2009 09:00
7210c no ear voice,no buzzer voice shailesh_chauha Nokia Base Band 5 ( BB-5 ) 1 03-20-2009 15:07
Siemens C35: no voice in speakerphone + anry x1x to x45/x50 1 01-05-2002 16:16
Siemens C35: no voice in speakerphone anry x1x to x45/x50 0 01-03-2002 05:19
Voice mail box Number on 8210 Meam Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 08-16-2001 09:58
Page generated in 0.23388 seconds with 10 queries
