3110 6300 phone restricted nokia 3110 sim inserted phonerestricted imei is ok try...flashing with hight version & use unlock command in jaf :confused::confused: |
phone blocked by network sir.......... |
Br. Vijendra Saini. |
your problem solveld with bb5king . |
Try to Repair your phone imei with bb5king.......... |
put ur logs here to help you |
Unlock it with bb5 unlocker......... |
Dear frinds. pls care while PM writing in BB5 If your using high MB PM file possibily two have to complaint 1,Phone resticted 2,sim not valid 1st solution unlock with jaf & ufs 2nt solution flash and unlock with UB box 3rd solution flash ic erase with ub box (after comlete erasing you can see imei number qousten mark.gest write IMEI) okkkkkkkkkkk |
kindly post logs sir.. so we can know what's wrong in your phone br |
nokia 3110 after water damages |
yes after water damage what happened more specific explainantion ??? br |
3110 6300 brother frist you do unlock with jaff box if same problem then get info and check the sp data maybe rpl problem |
u can use bb5 prince software to unlock 3110c network lock download this software click here http://www.4shared.com/file/76346131...B5_PRINCE.html |
ur sp data is corrupted...... just unlock it with bb5king.....ur problem will solved |
Use BB5 king 100000% ok |
