Old 11-16-2008, 08:55   #1 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
Arrow 3110 6300 phone restricted
nokia 3110 sim inserted phonerestricted imei is ok
try...flashing with hight version &
use unlock command in jaf
The Following 5 Users Say Thank You to suntysunty For This Useful Post:
Old 11-16-2008, 08:57   #2 (permalink)
howell's Avatar
Member: 697643
Thanks Meter: 68
phone blocked by network sir..........
The Following 3 Users Say Thank You to howell For This Useful Post:
Old 11-16-2008, 08:57   #3 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,513
Use BB5 king or tornado sim for removing phone restricted.
Br.
Vijendra Saini.
The Following User Says Thank You to Vijendra Saini For This Useful Post:
Old 11-16-2008, 08:58   #4 (permalink)
Member: 277710
Thanks Meter: 16
your problem solveld with bb5king .
The Following 2 Users Say Thank You to anastamir For This Useful Post:
Old 11-16-2008, 09:38   #5 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
Try to Repair your phone imei with bb5king..........
The Following 2 Users Say Thank You to prakash6464mh For This Useful Post:
Old 11-16-2008, 09:40   #6 (permalink)
Member: 205157
Sonork: 100.1574537
Thanks Meter: 81
put ur logs here to help you
The Following 2 Users Say Thank You to cellncare For This Useful Post:
Old 11-16-2008, 09:44   #7 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 66
Unlock it with bb5 unlocker.........
The Following 3 Users Say Thank You to sameer918 For This Useful Post:
Old 11-16-2008, 09:44   #8 (permalink)
Registered User
Member: 474045
Thanks Meter: 9
Dear frinds.
pls care while PM writing in BB5
If your using high MB PM file possibily two have to complaint
1,Phone resticted
2,sim not valid
1st solution unlock with jaf & ufs
2nt solution flash and unlock with UB box
3rd solution flash ic erase with ub box (after comlete erasing you can see imei number qousten mark.gest write IMEI)
okkkkkkkkkkk
The Following 2 Users Say Thank You to nishadpk For This Useful Post:
Old 11-16-2008, 09:56   #9 (permalink)
beezee_lao's Avatar
Member: 537853
Sonork: 100.1590344
Thanks Meter: 119
kindly post logs sir..
so we can know what's wrong in your phone
br
The Following User Says Thank You to beezee_lao For This Useful Post:
Old 11-16-2008, 18:07   #10 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
nokia 3110 after water damages
Old 11-16-2008, 18:09   #11 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 621
yes after water damage what happened more specific explainantion ???
br
The Following 2 Users Say Thank You to raezak For This Useful Post:
Old 11-16-2008, 18:50   #12 (permalink)
multi_mobile's Avatar
Member: 502659
Thanks Meter: 97
3110 6300
brother frist you do unlock with jaff box if same problem then get info and check the sp data
maybe rpl problem
The Following 2 Users Say Thank You to multi_mobile For This Useful Post:
Old 03-05-2009, 14:26   #13 (permalink)
Member: 445845
Thanks Meter: 34
u can use bb5 prince software to unlock 3110c network lock download this software click here http://www.4shared.com/file/76346131...B5_PRINCE.html
The Following 9 Users Say Thank You to sunil_1062 For This Useful Post:
Old 03-05-2009, 14:32   #14 (permalink)
gm33223322's Avatar
Member: 233686
Thanks Meter: 50
ur sp data is corrupted...... just unlock it with bb5king.....ur problem will solved
The Following 2 Users Say Thank You to gm33223322 For This Useful Post:
Old 03-05-2009, 17:13   #15 (permalink)
Member: 302843
Thanks Meter: 111
Use BB5 king 100000% ok
The Following 2 Users Say Thank You to mahesh123 For This Useful Post:
6300 phone restricted (enter restriction code ) seeta Nokia Base Band 5 ( BB-5 ) 32 08-25-2011 13:19
3110-6300 phone restricted s.s.s.s. Nokia Hardware & Hardware Repair 24 08-31-2010 21:41
6300 Phone Restricted SAM5 Nokia Base Band 5 ( BB-5 ) 11 09-29-2009 06:33
Page generated in 0.80031 seconds with 8 queries
