Old 11-20-2008, 07:48   #1 (permalink)
Member: 905210
Sonork: jedi_boy23
6300 Black Screen
My Nokia 6300 has a working battery and the phone is on but the LCD screen is completely black. Can anyone please help?
I've seen some similar forums for the Samsung U600 that speak of "reflowing" or reheating an "ic". Is there some similar solution for this problem? Can someone please include a diagram and explain to an electronics newb who only just knows what a soldering iron is what to do?
Much obliged. Thank you.
Old 11-20-2008, 07:56   #2 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
hello there,
for nokia phones with blank lcds/display.. problems are actually from here
1. Flex strip (if it is a slide or flip phone )
2. LCD (liquid crystal display)
3. Display ic and connectors
4. Phone CPU.
these parts or compartments are considered for such fault in nokia phones
Old 11-20-2008, 08:10   #3 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
this is wat u have to do first check if phone can make and receive calls, if it can, do a software upgrade that is flash fone with latest flash version,check fone if not work try a new and tested Lcd.. if nt work fault is majorly from Display ic.
Try changing display ic or make jumpper on display ic... phone will work Good.
Tested by me many times and works very well..Good luck
Old 11-20-2008, 08:13   #4 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
resolder flex from board
Old 11-20-2008, 08:15   #5 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 571
HI brother.....
1st change lcd
2st change display ic.............good luck
Old 10-28-2009, 02:43   #6 (permalink)
Member: 1094236
Sonork: sir d2 nku hnap kta
i change desplay ic and still black screen pls help
Old 10-28-2009, 05:37   #7 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.6300 complate lcd solution here.
click here
Old 11-13-2009, 16:26   #8 (permalink)
Member: 478331
Thanks Meter: 24
i have nokia 6300 with complet black no display no light in lcd but key pad lights are on
Nokia N81 8gb screen problem, artifacts and black screen.. DjDecibel Nokia Hardware & Hardware Repair 8 01-03-2011 18:15
K800i Camera Not Working Is Show Circle And Black Screen Photo Is Black guy_askali Siemens Hardware Repair Area 0 11-09-2007 15:57
6300 black screen MAX1981 Nokia Hardware & Hardware Repair 3 09-25-2007 14:54
V3 / V3r `Black Screen` or Flipping Screen solution. karwos Motorola Hardware Repair 3 08-13-2007 19:25
Page generated in 0.17049 seconds with 9 queries
