12-27-2009, 10:47 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: MobiCare, Mh-50, India
Member: 1019814 Status: Offline Thanks Meter: 653 | 3110 mmc corrupted???????/// |
12-27-2009, 12:31 | #5 (permalink) |
Crazy Poster Join Date: Jun 2009 Location: cordillera / philippines
Member: 1060222 Status: Offline Thanks Meter: 5 | just be sure that both IC's are good.. for sure.. get drivers from clean board or good/working board for you to know if its MMC driver which is damaged.... if you replace a good driver and its still no luck then its cutted line.. specially its water damaged... good luck sir... |
12-27-2009, 15:02 | #6 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan
Member: 652132 Status: Offline Thanks Meter: 146 | brother sometime the new one IC also do not work , change the black one IC , also look into the memory card socket , weather its pin are damaged or not , |
The Following User Says Thank You to $h@hidmobile$ For This Useful Post: |
10-05-2010, 19:13 | #9 (permalink) | |
Cheater -Don't Deal with him- Join Date: Dec 2009 Location: CH,BD,HK
Member: 1179761 Status: Offline Sonork: 100.1602000 Thanks Meter: 1,834 | Quote:
*3110c MMC Good Solution 100% Tested & Easy http://forum.gsmhosting.com/vbb/6311229-post71.html try & post result | |
nokia 3110 mmc solution | jai2008 | Nokia Hardware & Hardware Repair | 29 | 06-03-2011 08:00 |
3110 IMEI Corrupted! | Harisk | Nokia Base Band 5 ( BB-5 ) | 7 | 08-09-2009 15:02 |
3110 mmc problem | vicky kumar | Nokia Hardware & Hardware Repair | 8 | 12-07-2008 09:58 |
n70 mmc corrupted without mmc | jkthe1 | Nokia Hardware & Hardware Repair | 0 | 05-20-2008 12:43 |
[6681] mmc corrupt without mmc inside the phone | Johnvinsley | Nokia Hardware & Hardware Repair | 4 | 11-06-2007 13:36 |
