Old 06-08-2010, 11:48   #1 (permalink)
Registered User
Member: 1188423
Sonork: 100.1636686
Thanks Meter: 18
3110c all keypad not work
already clean pcb, change keypad ic, change side volume switch and rehot cpu. flash latest version.
plzzzzzz help me
The Following User Says Thank You to sanjay rana For This Useful Post:
Old 06-08-2010, 11:50   #2 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Thanks Meter: 760
Change again keypad ic .................
Old 06-08-2010, 11:53   #3 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
plzzzzzz help me
Bro.its keypad ic problem.
again replace original keypad ic.
Old 06-08-2010, 12:26   #4 (permalink)
Registered User
Member: 1188423
Sonork: 100.1636686
Thanks Meter: 18
already change 3 keypad ic brother
Old 06-08-2010, 12:35   #5 (permalink)
Crazy Poster
Member: 1152504
Sonork: 100.1615456
Thanks Meter: 13
when the crystall ic has been remove us tester on the keypad ic line through the front button, remove the stiker in thfront, u can able to detect what line is broken..
hope it helps..
The Following User Says Thank You to jeff_tech For This Useful Post:
Old 06-08-2010, 12:37   #6 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
dost...remove key pad ic short any 2 points key pad ic on board
toward upp side..... if some key work ...its mean upp is ok
and the problem is in keypad side
and if still no key work ....its mean upp is foalty or some
track is short toward upp side
Old 06-08-2010, 12:43   #7 (permalink)
javedsf's Avatar
Member: 811013
Sonork: 03468717163
Thanks Meter: 744
orgnal kepad ic chnga 100 okkkkkkkkkkkkkkkkkkk
Old 06-08-2010, 12:44   #8 (permalink)
Member: 1204784
Sonork: patil telecom
Thanks Meter: 3
very nice information brother ,,,,this proper testing method...thanks
The Following User Says Thank You to patil telecom For This Useful Post:
Old 06-09-2010, 14:29   #9 (permalink)
Member: 1321248
plzzzzzz help me
plzzzzzz help me
Old 06-09-2010, 14:30   #10 (permalink)
Member: 1321248
plzzzzzz help me
Old 06-09-2010, 14:38   #11 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
plzzzzzz help me
Remove keypad sticker, and check all keypad point's continuity to ground. If any track is showing grounded, change keypad ic again. Because, if any track under keypad ic gets grounded, none of the keys work.
Remove keypad ic, clean its place properly. and put new ic.
Post reply.
w.r.,
k_abhi
Old 06-09-2010, 14:54   #12 (permalink)
Member: 1321264
Thanks Meter: 68
remove volume key and check change key pad ic u r problem is solve bro
http://www.4shared.com/photo/mpULc1am/keypad.html
http://www.4shared.com/photo/qRe5MUf...sree20kri.html
The Following User Says Thank You to Shabbir Raza For This Useful Post:
Old 06-09-2010, 16:17   #13 (permalink)
the jinnah's Avatar
Member: 683063
Sonork: 100.1617868
Thanks Meter: 136
good job bro u r garet
Old 06-12-2010, 08:53   #14 (permalink)
Member: 1321248
pls help me on 3110 kypd prblm
Old 06-12-2010, 09:07   #15 (permalink)
Member: 1321248
all rdy change kypd ic ok no wrkng the kypd
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.30516 seconds with 9 queries
